Are you dead set on doing a Turbo? If you go for the entire 95 SSEi engine/Trans/PCM combo it would be easier to leave it Supercharged.. And Go to turbo later maybe? This way you can leave the stock tune and have good driveability..
When you want to turbo later you could gut the SC, use a block off for the nose drive and set it up for turbo..
boost-ablility
Re: boost-ablility
- BonneMe
Re: boost-ablility
You really should look at some turbo kits and builds for the 3800, not a lot has been done here on, and there's not really anyone active who has first hand knowlege of a Turbo build.phoenix_flame220 wrote:Say for example I found a 95 SSEi donor car and converted it to turbo the way you said, what kind of tuning changes would have to be made to the PCM? Since its already set up for boost would it be usable as is? Would the vacuum lines have to be moved to the inlet of the turbo now that the manifold is positive pressure? What about the MAF?
phoenix_flame220
- SSEi Member
- Year and Trim: 1990 SSE
Re: boost-ablility
I have been thinking toward the idea of having a 95 powertrain like you said, then converting it to turbo later if i choose to. I plan to do a remote turbo installation anyway so I wont have to pull the motor again. I have a question about PCMs though. What will happen if a turbo is used with the stock pcm? I know a tune will be needed, but does anyone know how it would react the way it is? Im looking at as many turbo builds as i can, but I havent found a definitive answer as of yet. Also, what happens if a PCM is used with a non electronic tranny but the tranny values are not deleted? Im not asking for the sake of using my tranny, just in general.
Last edited by phoenix_flame220 on Thu Jul 23, 2009 1:05 am, edited 1 time in total.
__/"""""\___
"-@--------@--" 1990 SSE " Black Ice " 215,456+ kms,
16" Streetwear Diablo wheels | FWI | Magnaflow cat | '94 top swap | MSD Ignition | Projector Retrofit w/ HIDs | Modded Mesh Grille | STB | Blue interior LEDs | LED 3rd brake light | Dynamat | Woodgrain delete | JVC NX-5000 nav/dvd | Infinity 1230W
http://www.cardomain.com/ride/674760/19 ... bonneville
- sandrock
- Retired Gearhead
Re: boost-ablility
If the PCM (if you use a 1997 and up) or the MEMCAL (94/95) isn't reprogrammed, your boost control will be awful. The computer will still think a supercharger is in play, which as you know delivers power much differently in both function and in powerband location than a turbo does. Boost control, timing, and injector pulse widths (and possibly injectors themselves) will have to be changed. Since all that has to be changed, might as well have all the trans values and associated codes nulled out at the same time. If not, you'll throw a CEL and possibly a limp home mode.phoenix_flame220 wrote:I have a question about PCMs though. What will happen if a turbo is used with the stock pcm? I know a tune will be needed, but does anyone know how it would react the way it is? Im looking at as many turbo builds as i can, but I havent found a definitive answer as of yet. Also, what happens if a PCM is used with a non electronic tranny but the tranny values are not deleted? Im not asking for the sake of using my tranny, just in general.
phoenix_flame220
- SSEi Member
Re: boost-ablility
is it possible to tune the stock pcm to control everything without having to add a stand alone system?
__/"""""\___
- sandrock
- Retired Gearhead
Re: boost-ablility
That's basically what I just said in the post above yours. Factory control computers will work just fine...it's the numbers inside the bin file that need to be changed.
