still running rough after lim gasket change
J Wikoff
Re: still running rough after lim gasket change
Post by J Wikoff »
Sounds like a loose rear tranny dogbone, and likely a torn up front tranny mount.
Mechanical Mike
Year and Trim: 99 SSEi
Post by Mechanical Mike »
I just read the entire thread, in one of your posts on July 2nd you stated the idle improved with the FPR vacuum line disconnected. Is that still the case?
2006 Chevy Monte Carlo SS
trf_ssei
Year and Trim: 1998 bonneville SSEi
Post by trf_ssei »
the idle actuall only changes until i plug the vac line then it runs the same after it stabilizes.(no change) unplug egr(no change). the trans dog bone is oil soaked and deterierating, the front mount looks alright but separates alot under load but ill put a bolt through that and replace the rear. im going to change the egr again that might help a little but the mounts need to be fixed. still doesn't guarentee a fix for the surging but the vibration should be lessened or eliminated.
willwren
Post by willwren »
The EGR isn't active at idle other than a one-time self-test. Unless your EGR line is cracked or the clamp is leaking AFTER the valve and BEFORE the LIM.
Mechanical Mike
Remove the oil filler tube from the valve cover.
Does the idle improve?
Is there a vacuum if you cover the opening with the palm of your hand?
