Fog Lights?
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
Get the 100W Sylvania or GE OEM bulbs. They're just as white and bright. That's what I run.
2011 Camaro SS
Bvill_GXP
Re: Fog Lights?
Post by Bvill_GXP »
So the 100Watts wont damage anything in the fogs? ie wires or melt the plastic!! Guess not since thats what your running!! I got to set a set!! Hope that will help.. Thanks
2005 Bonneville GXP Fully Loaded
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
Nope.
I just replaced the passenger side after about 3 months, about a week ago. I even think that bulb may have been used slightly before hand from my old fog light assembly. I swapped out the 55w bulb in the new assembly with the 100w from the old one, when I put the new assembly in.
2011 Camaro SS
SAMzGXP
Re: Fog Lights?
Post by SAMzGXP »
or HIDs :D
:banana: :banana: :banana: :banana:
Cardomain link
Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
HID's for the fog lights?
2011 Camaro SS
2.3 turbocoupe
Re: Fog Lights?
Post by 2.3 turbocoupe »
Yep, they make H3 true HIDs. I tried a setup from Ebay some time ago and they worked great initially, but then one ballast apparently went bad, and the other side lost a bulb when driving in the rain. So I'm done with that although I think others have had good luck.
CM - I dropped in a pair of 100Ws and love them. With the fogs properly aimed, my visibility is much improved to the left and right. When I turn onto my alley from a 2-lane road its hard to see the alley until you make the turn. MUCH better with the 100Ws. I never did this previously because I was worried they'd burn out even quicker, but I'm hooked now.
When I put the 100s in, I left the headlamps out initially, and turned on the fogs for 15 minutes. I felt the wires by the connectors and opened the loom to check further down and the wires did not get warm, so I don't think there is any strain on the harness.
2005 GXP Silver, Gutted Airbox, K&N filter, 14.61 @ 94.31 mph.
1987 t-bird 2.3 turbo, stock motor with home-ported head, big turbo, big exhaust, alky injection, a bunch of other little stuff, 13.65 @ 102 on radials.
93 SSE 4 ME
Re: Fog Lights?
Post by 93 SSE 4 ME »
CMNTMXR57 wrote:I would like to re-iterate how I wish that the children of the engineer who designed these driving/fog lights, suffer from some sort of venereal disease!!!
I thought this was a pretty harsh indictment until I saw the set-up. I swapped the burned out passenger side and the still functioning driver's side bulbs out for the 100W Sylvanias. Anxious to see them at night. It is certainly a piss-poor design. Combining the inaccessability with the H3 bulb was not the best plan... Thanks for the info and pictures tho, Pontiac Bonneville Club made things much easier once again.
Mark
'05 Bonneville SLE Intense FWI & PCM, Wood Dash Kit, Chrome Valve Stem Caps!
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
Glad you guys like them.
Yea, maybe I was a little harsh, I just couldn't get over the lame brained design when my first set went out. :D I realize the goal with the H3's was a much brighter light than a conventional 880 or 893 style fog light bulb, but at least make them easy to replace if they're gonna go out every other week. :)
2.3 Turbocoupe, interesting on the HID's for the fogs? It may be an interesting thought. I wonder if ballast location might have been an issue!?
2011 Camaro SS
Bvill_GXP
Re: Fog Lights?
Post by Bvill_GXP »
2.3 turbocoupe wrote:Yep, they make H3 true HIDs. I tried a setup from Ebay some time ago and they worked great initially, but then one ballast apparently went bad, and the other side lost a bulb when driving in the rain. So I'm done with that although I think others have had good luck.
Sweet...... Im going to pick up a set tomorrow and put them in after work!! my pass side been out for a month now and it's been replaced 3 times within the 3 1/2 months i have owned the car!! Oh well looks like the 100W blub will do the trick!!
Did you or CM leave the back for the fogs unscrewed and off to help with the release of the heat from the bulb? Thanks guys!!
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
Yes.
2011 Camaro SS
Re: Fog Lights?
This thread is still going............
Bvill_GXP
Re: Fog Lights?
Post by Bvill_GXP »
So none of the local stores had any 100w H3 bulbs.... SO I got a set from ebay which should be at my door sometime this week!!! Thanks for the info guys!!!
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
00Beast wrote:This thread is still going............
Are us GXP guys still blowing bulbs with regular frequency......
:booty:
2011 Camaro SS
Re: Fog Lights?
I haven't touched the fogs on dad's GXP, that's the saddest part. He doesn't care that much, lol.
bs009
Year and Trim: 82 GP
Re: Fog Lights?
Post by bs009 »
CMNTMXR57 wrote:FYI, our fog lights do not like Silverstar H3's. Seriously! I went through them on a weekly basis. Went back to a regular Sylvania, Wagner, or whatever bulb, in 100W rating, and they last a couple months (with the moisture caps off). Put a Silverstar back in (just to see), and they last a week. I don't get it.
the second biggest culprit here is the silverstar bulbs. obviously you've switched now, but fwiw silverstar bulbs are synonymous with having a much shorter lifetime than your standard bulb.
Bvill_GXP
Re: Fog Lights?
Post by Bvill_GXP »
Thanks for the heads up on the bulbs.... My Intrepid uses the same bulb as the GXP and it takes bout 2-4 months before i have to change them out....... Oh well, My 100Watt H3 bulbs should be here tomorrow.......
Bvill_GXP
Re: Fog Lights?
Post by Bvill_GXP »
100 Watt fogs came in this afternoon and i popped them in and they look great... Just hope they last more than 2 months...
donky4444
Year and Trim: 2011Taurus SHO
Re: Fog Lights?
Post by donky4444 »
I just changed my bulbs again Thursday and this time I left the caps off. I also just ordered the HID kit and am going to put them in hopefully next weekend if they come in this week. At this point I am willing to take a shot at it for the $55 the whole set up cost me on ebay. Pics and results will follow.
2011 Ford Taurus SHO, Livernois Motorsports Stage 4x+ tune, 3 bar MAP sensor, Motorcraft SP534 plugs, 160* Tstat, best ET 12.5612@ 108.96 MPH running 0.75 gallons of E85 to 13 gallons of 93 octane, 35% tint, 2013+ fender badges! debadged trunk and rear quarter window
2008 Grand Prix GXP Dark Red, Magnaglow Cat Back, Overkill Motorsports Tune, K&N FWI, 20% tint, 6,000K HID lows, 5,000K HID fogs and HIR highs (sold)
2005 Greystone Metallic, cleared corners, 20% tint, drop in K&N filter with gutted air box, 6000k HID low beams and fog lights, LED interior lights and reverse lights (sold)
CMNTMXR57
Re: Fog Lights?
Post by CMNTMXR57 »
I'm definetely waiting to see these HID's!!
Are they a completely different light housing? Or does this bulb fit into the GXP housing?
2011 Camaro SS
donky4444
Re: Fog Lights?
Post by donky4444 »
They say that they are direct plug in to the existing harness and housing. They come with all the connections, ballast and bulbs. I figured that for $55 it's worth the try since I have sent more than that on bulbs since I bought the car 2.5 years ago.
