Page 18 of 24
Re: Some pics of my 95 SLE (6/24 Update)
Posted: Sat Jul 15, 2017 10:05 pm
by 95naSTA
Appreciate it!
Re: Some pics of my 95 SLE (4:20 Update)
Posted: Sun Jul 16, 2017 10:15 pm
by 95naSTA
I finally got the new headliner done.. Not without issue either..
Since this is the 3rd time doing this, I wanted to try something new. The soda can weight method works for a lot of the contours but not all of them. So, I figured, why not spend 20 bucks on Plaster of Paris and make molds.
It took me so long to strip the OEM fabric that my wife actually offered to help me. Complete PITA.
I actually screwed up when I went to lay the suede down. There wasn't enough slack in between the front dome light bulge and the back of the sunroof. I cut open the sunroof hole to try and fix it but it ended up creasing the fabric beyond repair. I used an iron to separate the fabric but the board required some repair. The new suede came in over the past week so I went for round 2 with this attempt.
I decided I was going to glue down the fabric in sections, starting with the dome light first, just taking my time to avoid creases. It worked out pretty good.
Hopefully this is the last time for this.
Re: Some pics of my 95 SLE (7/16 Update)
Posted: Sun Aug 20, 2017 5:44 pm
by zuper8
Beautiful, definitely impressed by anyone who can do a nice headliner after I did mine (not nicely, btw). Going to do the headliner on my mom's Saturn soon, thanks for the plaster of paris tip! Looks well worth it!!
Posted: Mon Aug 21, 2017 12:13 am
by 95naSTA
I'm not sure why the first couple times I did the headliner went without a hitch, but I had much less of an issue then. What's funny is my wife's Jag needs the headliner redone and she keeps telling me she doesn't notice or not to worry about it.. I think It's because she saw how much of a PITA it was do to on my recent attempts.
Posted: Tue Jun 26, 2018 7:38 pm
by 95naSTA
This car has been on the back burner more or less because I'm not sure how much motorcycle seat time I'll get once my wife and I have kids. It's one thing if I get banged up pretty good when it's her and I but another when there's a kid to take care of. I've focused most of my attention to bikes recently and between that plus traveling, not much gets done with the Bonnie. I know for sure this is a forever car so I'll get to it. It'll just take a while.
Since I posted last, I removed the windshield to paint under the top reveal molding (haven't done that yet) and the headliner went in. A new carpet is also in but I still have to trim it up and install all the moldings.
When I was driving the car before the RPMs seemed to want to drop too fast when I was out of gear. It was to the point where it would almost stall. I know there's a table for throttle air follower in TunerCATs but I wanted to be certain I don't have any vacuum leaks. So, I made a DIY smoke tester out of an old paint can, some fittings, air hose and a 5lb pressure regulator. Turns out one of my injectors wasn't seated properly and the back of the throttle body wasn't making a good seal with the UIM gasket ring. I removed all the 14 year old JB Weld and redid the back of the L67 TB to make a better mating surface. The injector in question sealed up with just some cleaning of the bung and lubing the O-rings. With that out of the way whenever I tune this thing next, I'll know that changing the throttle follower table isn't a band-aid.
Re: Some pics of my 95 SLE (6/26 Update)
Posted: Sun Sep 09, 2018 6:56 pm
by 95naSTA
Posted: Sat Dec 28, 2019 10:46 pm
by 95naSTA
I'm slowly working to getting the car ready for a re-paint.
One of the biggest things to repair other than the windshield channel is re-doing the E39 headlight bodywork. I decided to start over with the hood for the following reasons. Most if not all of it could be fixed but it bothered me enough to want to redo it better.
-Dent from when my strut punched my hood in an accident in 2010
-Dents on the sides from bending the hood back after it flew up in 2012ish
-A dent from my motorcycle bar end
-Passenger side bodywork had a blemish
-Bodywork underneath the hood associated with the headlight molding is rough and started to fail
-Rust developed under the hood since it was only ever primered underneath
They stopped making aftermarket hoods for the 92-99 H-body at some point. Companies still say they have them in stock, but they don't. I wasted a fair amount of time dealing with this. I decided to get a used OEM hood from Ed Morad since the one he had in stock was cleaner than anything I would find in any yard I could reasonably drive to. I used uship.com since Ed stopped shipping larger fragile items a while ago. I paid a premium all said and done but it ended up saving me a lot of time.
The new hood needed to be clearanced underneath and grinded down near the grill to accommodate the larger lenses. New material needs to be added to the hood to extend it over the lenses as it approaches the fenders. The last time I did this, I just tack welded some thick gauge mild steel in for support and then added kitty hair, then bondo. Structurally this help up pretty well on the exterior but I wanted to redo stronger with less filler.
I kept the front section of the hood that was replaced on my 528i in hopes of using as much of headlight cutout as possible. The E39 hood is a bit more narrow than the Bonnie's. Instead of extending the headlight section of the E39 hood to use it, I'll just use the new sections more outboard. After a lot of cutting and checking, I temporarily tacked the driver side transplant section on the hood to see if is close. It just needs to come up a hair on the inside. The extra material on outer edge is intentional for when I square off the end. The new section will come back off, I'll copy it for the passenger side, then start the permanent attachment and body work.
The good thing with this version is I'll have a nice lip to weld on underneath to attach most of the bottom. For the single wall clearanced section underneath, I'm just going to epoxy it along the perimeter, similar to how the skeleton is jointed throughout.
Last time:
Underhood rust and bodywork failing:
Re: Some pics of my 95 SLE (12/28 Update)
Posted: Mon Jan 20, 2020 11:53 pm
by 95naSTA
We had a few warm days but that didn't line up with when I was home so no progress on the hood.
I'm able to get my garage about 10 degrees above ambient so I decided to finish up an SSEi suspension air pump install I started a while back. I've had the shocks for 10 years with the Monroe schrader valve kit. A couple years ago I saw an SSEi at the yard and decided to take the pump along with the latch trim with the factory schrader valve on it. I swapped out latch trims and plumbed in the pump in but never wired it up.
To control the pump I chose a 3 way rocker switch so I could air up and down with one switch. I was originally going to cut a hole in my dash trim to the left of the steering wheel for the switch.. Then I started thinking how I don't have a spare dash trim piece in good condition.. If I change my mind down the line or have to use a different switch, I would have to repair it. Then I started thinking about the SSEi dash trim and lo and behold, the SSEi piece has a recessed hole for the HUD controls right where I was thinking of putting the switch. It also has that gain switch under the radio that would be unused, but I'm sure that wasn't too impressive anyway. I found a cheap SSEi dash trim piece on ebay which was actually in better shape than mine. Since I already had 3 HUD control boxes, I decided to hollow one out plastic weld a new face on it and mount the switch in it. This way I could swap switches in the future pretty non-invasively.
For wiring, I cannibalized some pins from my previous 95's fuse box and added a fuse to the driver's under dash fuse panel. I used an existing line originally for the antenna (shaved) for +12 to the exhaust solenoid and I ran a new line of thicker gauge back to the pump. One of the old mounting points for the antenna or the jack box now has a stud for the ground.
Forgive the dust.. and lack of light.
And a video.
If you jack up the volume, you can hear the pump in the background. The lights above the pedals are a part of the 6-speed rewire. They're in place of the shift solenoids.
https://www.youtube.com/watch?v=m-9X7AAuinU
Re: Some pics of my 95 SLE (1/20 Update)
Posted: Tue Jan 21, 2020 12:25 am
by J Wikoff
I dig it. When do we get rake photos?
Posted: Tue Jan 21, 2020 11:34 pm
by 95naSTA
Thanks. Honestly, it'll be a while. I need to get the windshield back in before the car is back on the street.
Posted: Sun Jan 26, 2020 8:26 pm
by 95naSTA
I got a little more work in on the hood today but unfortunately my MIG gas ran out.
Both hood extensions were trimmed a bit more to completely line up with the hood. All the raw metal mating surfaces were coated with copper weld through primer. The driver's side is completely welded on the top and tacked on the bottom. The plan is to get to the same spot with the passenger side then flip the hood over to completely weld up the bottom on both.
Re: Some pics of my 95 SLE (1/26 Update)
Posted: Wed Jan 29, 2020 9:13 pm
by 95naSTA
Re: Some pics of my 95 SLE (1/29 Update)
Posted: Sun Apr 12, 2020 9:23 pm
by 95naSTA
Slow progress is better than no progress..
Yesterday I ground down any flash rust and hit most of the bare metal with self etching primer.
Today I started dipping into bodywork. My bodywork skills are rusty so just getting this kitty hair layer on and knocked down to my liking took most of the day. Next is to get some light weight bondo over this and block it along with the fender to make sure they're level. The kitty hair is intentionally a little low.
It's kid of a bummer, painter's tape pulled off the sealer I had on the lens but they were yellowing anyway.
Re: Some pics of my 95 SLE (4/12 Update)
Posted: Mon Apr 20, 2020 7:12 pm
by 95naSTA
Jumped back into this after coming off travel yesterday. I'm starting to get my bondo legs back.. It just took one swipe to get to where I wanted to be on the passenger side with the kitty hair. Although, it did take a long time to knock it down to where I was happy with it.
Posted: Tue Apr 21, 2020 9:00 am
by Sirius
That's looking pretty amazing. But isn't it about time to blow the winter dust off the Yammie and see what's going on in the woods?
Posted: Tue Apr 21, 2020 10:02 am
by 95naSTA
Thanks.
You're not kidding.. I have been itching to do that but it's tough since I would have to be in a buddy's truck to go anywhere good. That woudn't be a good idea since I've taken over a dozen flight segments in the past month and a half for work.. Hopefully a trip I have in 2 weeks gets pushed to the right and that'll give me the self isolation buffer time to grip it and rip it. Or.. Maybe I'll take the DRZ somewhere..
I have been ripping solo on the other Yammie (DS7) a good bit. I actually went out about 15 mins after I got home Sunday.
Posted: Fri Apr 24, 2020 10:04 pm
by 95naSTA
Re: Some pics of my 95 SLE (4/24 Update)
Posted: Sun Apr 26, 2020 5:01 pm
by 95naSTA
Yesterday I grinded down the passenger fender and had another rivet party. I prepped in between added E39 sections and the original fenders as best as I could then pumped 3M panel bond in between. To make sure I filled the area I drilled some access holes to inject and watched for the epoxy to bulge in other areas. After the epoxy cured I clearanced the inside corners where the E39 under headlight trim hooks in.
Now that the front fender section bonds are strengthened, the fenders can go back on and more bodywork can resume.
Re: Some pics of my 95 SLE (4/26 Update)
Posted: Mon Apr 27, 2020 9:50 am
by Sirius
My stock in Acme Blind Rivets went through the roof over the weekend. Thanks!
Posted: Mon Apr 27, 2020 10:30 am
by 95naSTA
Lol. It's only about triple the original amount.
