Restoring the SSEi: F40 swap, HIDs, and a HY35 turbo.
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: Restoring the SSEi zombie: 3.25 MPS video update page 1
Post by 2003 SSEi »
The Grand Am Ram Air hoods are not metal, they are SMC (Sheet moulded compound)
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
I may be 1/2 a step ahead of you guys on that one :-#
devin1986
Year and Trim: 2000 Buick LeSabre
Post by devin1986 »
Last time I peeked at this project it was... eek. You've made a ton of progress, and you should be proud. I'm also jealous because I don't have a good tuner readily available.
-2002 Pontiac Bonneville SE
gone, but I'll never forget it-2000 Buick LeSabre Limited, top swapped, ported gen3, MPS pulley system, FWI, SD headers, hockey puck mod, thrush turbo, 255lb pump, 180 t-stat, 245s on bullitts, and maybe some other things that I forget.
2003 SSEi
LOTS of Mods
Post by 2003 SSEi »
MattStrike wrote:I may be 1/2 a step ahead of you guys on that one :-#
i doubt it. ;)
I have a Grand AM Ram Air Fiberglass hood, and a 00+ Bonneville hood, that are cut and pasted :-$
MattStrike
'92 Trofeo
Update time!
As everyone probably already knows by now, I've upgraded to 4-wheel disc brakes last week. Info here. Part of that was upgrading to F-body dual piston calipers, as well as a set of W-body KYB AGX struts (Thanks to info on Pontiac Bonneville Club and 95naSTA!). I grabbed a random set of W-body springs that seem to have lowered the front between 1/2" and 1" total. To complete that mod, I need a set of W-body crosslaces or some nice big rims and adjust the brake balance front to rear.
Then at the MI mega meet last weekend the input shaft on my 4t65e-hd broke. Sheared off right at the TCC O-ring groove. Combination of vehicle weight, shift kit, and power I think. The trans had started shuddering on the way up under load. But if something is going to break, I want to be the one that does it!
The cost it will take to upgrade the 4t65e for the current and likely future power level it will see is not at a significant margin different than a swap to a trans that is a little more stout and a lot more fun.
I'm picking up my 'new' used F40 manual transmission tomorrow and will be ordering the necessary parts for the swap over the next few weeks. There is enough of a road-map laid out by previous swaps that I shouldn't have any major hurdles. But I'm going to try to find an OEM solution to the C/V axles - hopefully corporate standards force a common spline x diameter for the center shaft on axles across similar platforms. This should increase power to the wheels as if I'd just pulleyed down again. And that might also happen in the process. 13's; here I come! (Broken F40, totally worth it!)
But for now, I will be scouring car-part and ebay looking for everything I need to pull this off. Part of me wants to rebuild everything and buy everything brand new. I'm at least going to crack open the trans and make sure nothing is damaged or needs to be replaced. But I'll try to get everything used first. Because I'm sure there is something else that needs to be upgraded along the way :lol:
I found my oil leak too. Gummy thread sealant on the oil pressure sender was the culprit. This also gives me a chance to remove the extra harness from the DS passthrough and fix some other things that were bugging me that I never finished before. And to make touch-ups to a spot of rust that I missed. And redo some paint, check how well the hockey puck mounts are holding up, make some custom PU motor and trans mounts, hood scoop V2.0.......... #-o
SSEiMan01
Post by SSEiMan01 »
:happy1:
James May wrote:Hello.
yourgrandma
Year and Trim: '02 SSEi
Re: Restoring the SSEi zombie: Time for a F40 swap!
Post by yourgrandma »
Youre a menace.
I like it.
95se
Year and Trim: 1995 se bonnie
Post by 95se »
so this means a stick shift bonnie?......
1995 se
128,101
custom FWI
rt-95 rims look kinda like crosslaces
6000k hids
f- body muffler dual output
96-99 headlight conversion, clear markers
MattStrike
'92 Trofeo
It means a 6-speed stick shift Bonnie.
95se
Post by 95se »
This should be interesting...bonnies gonna burn thru more tires
1995 se
128,101
custom FWI
6000k hids
SSEiMan01
Post by SSEiMan01 »
Tires are cheaper than transaxles.
95se
Post by 95se »
Very true burning rubbers more fun than breaking things
1995 se
128,101
custom FWI
6000k hids
MattStrike
'92 Trofeo
95se wrote:Very true burning rubbers more fun than breaking things
Is it too much to ask for both? :twisted:
95se
Post by 95se »
Not at all both are more fun in my opinion!
1995 se
128,101
custom FWI
6000k hids
MattStrike
'92 Trofeo
Picked up my trans today. Surprise! 0 miles!
Test fitting, almost cleared but not quite. I'll be modifying the header and flange:
I'll have to notch the header or use the bolt through the block:
Looks like i have an A/C leak and an oil leak on my balancer seal:
Woah! Where'd you get a new trans?
*dang* you work quickly.
SSEiMan01
Post by SSEiMan01 »
I wasn't kidding when I said he'd have it done quickly. :P New trans eh? It has no idea what it's in for. It thinks it's going to some little old G6. :lol:
yonkerse
Post by yonkerse »
I'm so hooked to this thread already it's not even funny. You are ridiculous! Can't wait to see this complete! Will you hurry up already? haha
Eric
A few mods..
ga93sle
Year and Trim: 06 Grand Prix LS4
Post by ga93sle »
:banana: :bwoohoo: :woowoo: I'm so excited to see this come together, more excited about this than any mod I've seen on here in a while lol!!!! Makes me wish even more that the GP GXP had came with a 6-speed...
*Chris*
15 Nissan Altima 2.5SL/2004 Honda Shadow 750 Aero
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
I can't wait to go for a spin in it! You could drive it here to swap my trans next Matt. :woowoo:
