Could the COT protection be conflicting with the AFR we wanted on PE? (if there's no 02 bank2, how can the PCM read the temp of the Cat anyway?)
Are there any drawbacks or issues with disabling the CAT protection? Is that a best practice in tuning?Allmachtige wrote:On the phone PDXGTP said CAT protection can cause PTKR (partial throttle KR).
Once I feel comfortable I'm writing a calibration with it set to 258.
I hate to be a wet blanket, but I would advise that you get all these bum lines in the vacuum system fixed up 100% before you continue your tuning.99ssei wrote:Yes, I used a lot of electrical tape to make a good seal. Matter of fact, I went to the dealership last night and ordered all the form fitted hoses and metal hose (taped up like hell where it's starting to rust) for the EVAP system. EVAP canister also on order. When car is hot (80+ degree day) and been running for an hour, I get this fuel smell inside and outside the cabin. I thought it might have been my new A/C, but since I've had EVAP codes come up, I think the filter in the canister isn't working or something.agrazela wrote:Maybe I missed it, but did you ever fix this vacuum leak?
Will do in the morning. I'll post and number the pics.Foghorn wrote:Need to see your plugs...can you take them out, number and photograph them then post here?
Cheers,
Yes. I will try pulling them again today to take better pictures (got some advice on how to take better pictures...thanks Haro!)Foghorn wrote:Is this more or less what the plugs look like?
Plot value - Sensor: InjectorAllmachtige wrote:What plot data are you using to get that Pulse Width, Injector histogram?
