Be sure to lube the caliper slides. Make sure they move freely. You should be able to move them by hand.bonnevillain wrote:I just switched my front tires to the back, there is about 3" of snow on the ground and still coming down, so no way will i be able to get up to 75 or so today, but tomorrow i will let you guys know if anything changed. next on my list is warped rotors (i doubt they could be causing this much vibration, but they need to be done anyways)
add me to the list (vibrations)
imidazol97
- Posts like an L67
Re: add me to the list (vibrations)
bonnevillain
- Year and Trim: 2002 SLE
well, 99% sure i have a bad tire. moved it to the back, and it's much better.
Not another one!bonnevillain wrote:well, 99% sure i have a bad tire. moved it to the back, and it's much better.
bonnevillain
supposedly it was out of spec... they replaced it, and the vibrations did get better, but there is still a little something there. I don't think it was there when i bought the car, but maybe i'm getting anal now
I have now owned 10 Triple tread tires in 6,000 miles. that's gotta be a record!
(4 originals, one blew out so i replaced them with 4 new ones = 8)
then 1 more blowout, and this bad tire. ugh.
Also, i marked your reply as solving this, because it was the only one i could click
- Whitecrystal1
- Posts like an L36
- Year and Trim: 10 Silverado
Have you replaced the rotors yet? Maybe that will clear up the rest of it. Glad you got it fixedbonnevillain wrote:supposedly it was out of spec... they replaced it, and the vibrations did get better, but there is still a little something there. I don't think it was there when i bought the car, but maybe i'm getting anal now
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
San Juan Cruiser
- SE Member
- Year and Trim: 2000 SSEi
Glad you solved part of it, vibrations are VERY annoying.
INTENSE 3.4 mps, High flow cat, AEROFORCE scan gage, NGK TR-55, 180* drilled stat, K&N dropin in gutted airbox.
biohazed
- Year and Trim: 2000 Grand PRix GTP
if the tire place you go to doesn't have a road force capable balancer i would definalty look into finding a shop that did that machine can help you find the optimal mounting position for the tire vs the rim and also tell you if your rim is bad or the tire is bad or both.
- 2000 Bonneville SE 3800 Series 2, Aluminum LIM Gasket, Dorman Improved UIM - Sold
bonnevillain
they do have one, that is how they figured out the tire was out of spec. they won't do it for free though, the normal balancing are free since i got the tires from them.
- Ponch 04
- GXP Member
My boss had 4 new Triple Tred tires installed on his '06 Caravan and had to deal with wheel vibrations for 5 weeks. He had them checked out. After numerous rotations and balancing, the tire shop concluded that the tires were out-of-round. He ended up exchanging them for a different tire at no cost.
2004 Bonneville SE: Dark Ming Blue Metallic (1 of 778), Bench seats, Cloth Interior, Beldin wires, Power Stop Rotors, 274724...... RIP
No issues here with triple treds after almost 3k and a rotation.
if you have original equipment firestones, i suggest NOT replacing them with the same. i had the 'bad vibes' from about 65-72 mph with replacement firestones that ended up being shifted belts in three (3!) brand new Affinity's
(i think, its been awile) within 5000 miles. i've nothing but good to say about the Bridgestone potenza 009's, & am on my 2nd set with no vibe issues if i keep them balanced every 5-6 k miles. hth's.
