CAI vs. FWI
willwren
Re: CAI vs. FWI
Post by willwren »
K&N has a reputation for performance. Their filter is widely regarded as the benchmark all other filters are compared to.
They do not hold water.
Spectre filters hold water for quite some time. That means they flow less per given surface area. And most are smaller to begin with than what most of us use. Not only that, but with the tighter 'weave', the plug up sooner and flow even less in a shorter period of time.
MadMike
Year and Trim: 2003 Bonneville SSEi
Re: CAI vs. FWI
Post by MadMike »
well, i ordered a new K&N filter, but im keeping the stock piece because i realized, that the adapter i made out of a piece of smooth plastic tubing, fits the entire inside of the "accordion" :beerchug:
Miles: 80k - Color: Maroon - Rims: aSa sport CD - Tint: 5% ^-^ - cleared fronts - ebay blue high/lowbeams - custom amber turn signals
247whp301chp321tq - 3.4 MPS - Brian Tuned PCM - FWI w/ 9" K&N - 3/4" TB spacer - Alternator Voltage booster w/ 8ga running wire - SLP Headers/DP - HF Magnaflow Cat - Custom 2.5" Exhaust w/dump cutout - Magnaflow mufflers - 103AL@55 - Beldon Wires - MSD ignition - 1.8 Yella Terra roller rockers - 105# valve springs - custom push rods - locks - retainers - Meisure electric water pump - shift kit - false knock kit -
harofreak00 wrote:If you can't afford the fuel for a premium sucking car, you shouldn't be driving it. Sell it for an N/A.
willwren
Re: CAI vs. FWI
Post by willwren »
Mike, plastic is a very poor choice for intake materials. After all the work you've done, you could have just installed a real FWI from INTENSE.
Plastic heatsoaks easily, especially right above the crossover as yours is. Different plastics also vary greatly in their melt point or SOFTENING point, which is typically far lower than the meltpoint. That being the case, right above your crossover, I gaurantee during the summer, that piece of plastic will be exposed to brutal temperatures in excess of 200 degrees, especially when stopped at a light or in traffic.
If it's installed like I think it is, it'll collapse and allow unfiltered air to leak in. HOT unfiltered air.
MadMike
Re: CAI vs. FWI
Post by MadMike »
HERES WHERE I GOTCHA! lol
i used a piece of heat resistant *chimney ballast tube(up to 500*) ;)
im not a dumby, i knew what top use, and i dun used it :P
*idk what the @$%# a chimney ballast tube is either :P
i got it from ace hardware, and it says its used in extreme temp. :bwoohoo:
guess i should've mentioned what kind of plastic it was
willwren
Re: CAI vs. FWI
Post by willwren »
That doesn't get around the fact that plastic absorbs heat easily.
Mike, Get some aluminum tubing in there instead.
MadMike
Re: CAI vs. FWI
Post by MadMike »
:salute: yes sir!
willwren
Re: CAI vs. FWI
Post by willwren »
:lol:
You'll get there. You just took the project on AT THE WORST TIME POSSIBLE!
:bsmack:
MadMike
Re: CAI vs. FWI
Post by MadMike »
willwren wrote:AT THE WORST TIME POSSIBLE!
:bsmack:
whys that? cuz its summer?
Looong4
Year and Trim: 03 SLE
Re: CAI vs. FWI
Post by Looong4 »
I just got a fwi from JMB. Came with a K&N. Very happy with it so far.
Kinda upset it didn't come with a pcm holder like Intense though...
http://jmbperformance.com/store/product ... ucts_id=86
willwren
Re: CAI vs. FWI
Post by willwren »
:bsmack:
No, during a massive forum move. ;) People are still settling in, and there's a ton of work still going on behind the scenes.
MadMike
Re: CAI vs. FWI
Post by MadMike »
willwren wrote:
:bsmack:
do i get to do any of the work? lol
i think its the perfect time for a project!
like remapping your pcm on the side of I-90 for tits and giggles :laughing1:
so, on a side note, im garaging my car for a while, my breaks are now the loudest thing on the car :helpsmilie:
(DISCLAIMER) its been almost two years since i changed them, i think they've lasted long enough
willwren
Re: CAI vs. FWI
Post by willwren »
Start a new topic on the brakes. If you want OEM, put it in the 00-05 section. If you're looking for a bit more, post a new topic here.
We'll keep 'em split that way. So people can search on the two topics later. ;)
MadMike
Re: CAI vs. FWI
Post by MadMike »
all fixed! :banana:
replaced the generic POS filter with a K&N
Part # RE-0950
and the plastic piece is now a piece of 3.875 outside diameter aluminum tubing ;)
custom milled to meet my specifications by a good buddy :)
it fits perfectly inside the "accordion" so its a smooth ride through the whole intake :beerchug:
