Page 2 of 2
Re: P0171 and starting issues
Posted: Sat Oct 18, 2008 11:27 pm
by Mechanical Mike
I'm not sure of the exact location on the 2000+ but somewhere on the fuel rail there's a schrader valve that you can press to relieve the fuel pressure. Pulling the relay would also work just fine. If the FPR is the same as the 99's then you just remove the snap ring & wiggle it until it pulls out.
Posted: Sun Oct 19, 2008 12:32 am
by azmedic85308
Trying to get that snap ring out now...it is a PITA!!!
Posted: Sun Oct 19, 2008 12:57 am
by Mechanical Mike
These make it easier.
Posted: Sun Oct 19, 2008 2:28 am
by azmedic85308
Ok the FPR that autozone sold me wont fit in my car....its a GP Sorenson, its whats listed as the replacement for my FPR, but the male end is too wide for the car.
Posted: Sun Oct 19, 2008 3:09 am
by azmedic85308
got the old one back in...just not sure where to get a replacement one as the autozone one listed for the car does not fit.
Posted: Sun Oct 19, 2008 10:23 am
by Archon
Was it by comparison that you found that it is too large, or by not being able to get it in? The O-rings on the new ones can make it pretty tough to insert. You could try a tiny bit of silicone grease on the O-ring. Otherwise, try NAPA, Advance, or other nearby parts store.
Posted: Sun Oct 19, 2008 9:24 pm
by dirtracr95
fixing the FPR should get rid of your PO171 (too rich). If your MAF reading is not changing when you plug and unplug it then i would suggest checking for signal at the PCM. I dont remember which cavity its in right off the top of my head but a wiring diagram will tell you. If you dont get a signal at the PCM then it maybe the wiring going to the PCM. Do you have any other DTC's?
Posted: Sun Oct 19, 2008 10:18 pm
by Mechanical Mike
Actually P0171 is thrown when the system is too lean. I think he may have two problems.
