You just mentioned water injection. Do you have any other info on METH injection? The rates at which they cool are different. I was following a Thread on one of the turbo regal/GN sites about the differences between water injection and meth injection. I have to try to find the post.2000Silverbullet wrote:The minimum amount of heat added by compressing air to 8 psi at 100% efficiency according to Boyles Gas Law is 71*F.How much lower specifically? I've been wondering this for a while.
The compressor's efficiency will add additional heat. For instance if it is 75% efficient, it will add another 24*F of heat.
I have noticed about a 10*-20*F drop in temps after converting to the Gen5.
Engine heat soak will add additional heat. My engine heat soaks to 160*F.
The normal running temp of my SC outlet air is 120*F with IAT of 50*F, so the heat gain is 70*F
At 8 psi the SC outlet temp spikes almost immediately to 190*F, so that seems to correspond to the 70*F rise due to compression.
That means the other 70*F is due to compressor efficiency and heat transfer from the 160* engine.
The water injection will knock the temp down to 140*F at WOT so it cools about 50*F. Not as much cooling as the SSIC that claims 80*F.
You honestly think a meth injection system with a solenoid that can stick pumping water/meth into your intake is any safer than an intercooler?Ah, yes actually!
I was referring to the risk of heat exchanger failure and dumping coolant into the engine in a very high quantity.
The meth injection is a very low volume system. It is very fail safe also. The solenoid failed closed so the engine just bogged from running rich. Still ran a 13.5 with no injection.
And what percentage of Water to Air intercoolers fail? I havnt really heard of any cases. Sure the possibility is there, but so the possibility of the methanol catching fire underneath the hood.
