Page 2 of 2
Re: 2000 SSEi Drivability issues
Posted: Sun Jan 03, 2021 7:58 pm
by 96 SSEi
hi, happy holidays, New Year, merry Christmas.
slight rocking side to side? at what speed please?
explain this rocking pl.
Posted: Wed Jan 06, 2021 3:37 am
by smokingfang
96 SSEi wrote:hi, happy holidays, New Year, merry Christmas.
Happy New Year!
It happens when maintaining constant speed and only after the car really warms up.
So if i drive it for 20 mins from cold start, i'd not experience it but when it gets to temp it starts to jerk very very slightly. It feels like a miss, but a minor one.
It will go away when accelerating. But as soon as i try to cruise on the highway i can feel it. When in park i can feel it slightly too.
No codes.
It has new
coils
ICM
leads
plugs
injectors
FPR
Smoke test showed that there was a very slight vacuum leak at the EGR tube. I will tackle this next.
Posted: Fri Jan 08, 2021 3:20 am
by smokingfang
I am now inclined to think its a drivetrain issue. The shake at idle is gone with new injectors. But at speed when maintaining constant i feel a jerking as if tranny is trying to down and up shift at the same time.
This evening i started hearing a creaking noise coming from the driver side front corner. Cv axle on that side has a slight play left to right. Can a bad cv axle cause this sort of jerking at constant speeds.
Posted: Mon Jan 11, 2021 10:45 pm
by smokingfang
Issue resolved. It was the TPS. With a new TPS all is well.
Posted: Tue Jan 12, 2021 10:17 am
by Namrepus28
smokingfang wrote:Issue resolved. It was the TPS. With a new TPS all is well.
Hey, glad to hear it!
Posted: Tue Jan 12, 2021 2:28 pm
by santacarl
smokingfang wrote:
Still got that bucking when doing constant speed.
I had a "bucking" at constant speed that turned out to be torque converter related. It was having trouble "deciding" when to go into overdrive and would stumble in the moment it tried to engage. The easy way to check is to get up to speed where OD kicks in and then move the gear shift out of OD into drive (3rd gear) to prevent it from trying to shift into OD. If the "bucking/stumble" stops you have your answer....
Posted: Tue Jan 19, 2021 2:52 pm
by 96 SSEi
Posted: Thu Dec 16, 2021 11:42 pm
by woody_02silverse
Hi santacarl,
I had an '02 Bonneville several years back, thus membership in the group. Now I have a 2010 Buick Lucerne with the same 4T65 transmission doing this 4th gear 'bucking'. Constantly, below 2000rpm but above 40mph. Above 2000rpm its perfectly smooth. Doesn't do it in any other gear so I'm thinking torque converter going in and out of lockup. What did yours need done a new lockup solenoid? My last trans filter change was about 60k miles ago, I've read that a plugged filter can cause all sorts of issues I'm hoping its that simple. ATF Oil change was 20k ago and it still looks like a good color. I replaced the TPS because that was an easy one and probably due (166k miles) but it didn't help.
Edit, next day: I did a trans oil filter change (there was 68k miles on the old filter) and fresh Valvoline syn oil and its driving perfectly now! I think the filter was plugged up effecting transmission pressures. I also added a bottle of LubeGard 60902. I tore the old filter apart it was very dark and didn't pass light very well held up to a light. No metal in to to speak of except fine common chips. I have the dual magnet kit so cleaned the magnets off good they were pretty caked with fine particles. I guess that's to be expected at 164k miles!
