Re: Project 57 - update 12/13/21
Posted: Mon Dec 13, 2021 4:18 pm
It’s been slow going on the 57 Chevy. Fortunately I’m not in a hurry, but I did make some progress recently. The brakes don’t work so I’ve been thinking I should be able to stop it before I make it go. To that end I grabbed a couple neighbors and pushed it up onto the 4-post lift. With a little help it wasn’t too bad a task, certainly couldn’t have done it myself. My wife wouldn’t get in and steer after the last episode with the brakes, so I had my 16 year old granddaughter steer it in. She got it pretty well centered.
That’s where it’s been sitting for the past couple months. But it’s up out of the way and not taking up a lot of floor space.
I was feeling froggy a week or so ago and decided to take a look at the brakes. I’ve got a new master cylinder and 4 new wheel cylinders and figured I’d crack the drums open and see what shape they’re in. I started with the left front because it was easiest to access. Once I got the drum/hub assembly off, it took me a second or two but I realized one of the problems with my brakes. At first I saw that one of the pucks was popped out of the wheel cylinder. Ignoring the 30 years or so of cobwebs, can you see the other problem?
If you’re unfamiliar with drum brakes, compare to what I found on the right side.
Yep, there’s no brake hardware on the left side! LOL! Cracked me up when I finally realized it was all missing. Didn’t see that coming! Fortunately all that stuff is available from repro vendors. My thought for fixing the brakes was mostly so as I moved it around, whoever was steering could stop it. This put a wrench in my quick-fix plans. I’m going to eventually convert to disc brakes, in the front at least, so I thought maybe I should bite the bullet and do that now. I did some research and found what I think is the conversion kit I want and was about to pull the trigger. Then I realized the temporary wheels on the car are 14” and the disc kit will require 15” disc brake wheels. I’m going to go to 15” anyway, but I’m not ready to buy rims & tires just yet so I’ve elected to restore the drums for the time being.
My plan at this point is to get the car drivable, mainly so I can move it around by myself. Therefore I was thinking I’d just rebuild the 283 that came in the car. It’s been sitting quite a while without a carb, so I’m pretty sure even those guys from Road Kill wouldn’t attempt to start it. It came with a 2bbl intake manifold and I’d like to put a 4bbl on it so I’ve been looking around for a manifold. I wound up finding a stock 57 4bbl intake with a 283 Power Pack engine attached to it. “Power Pack” prolly won’t mean much to many of you, but it was a performance option for the early Chevys. Anyway, I picked it up for $80 and it was about 4 miles from my house. This engine also needs a rebuild, but it has the Power Pack heads with 58cc combustion chambers, 4bbl intake, and forged crank. Since this is the livelier engine of the two, and it’s a 1957 block, I’ll just rebuild this one and stick it in the car. I’ll decide later what I want to end up with, but for now this should get it around the block.
I know, it doesn’t look like much, but the heads alone are worth $200 all day long. I can roll it over by hand, which I can’t do with the engine that’s in the car – so that’s a good thing. I'll break it open soon and check out the cylinders. If there’s no ring groove maybe I can get away with a hone and some rings. We’ll see.
