Page 2 of 6
Re: 02 Jag X-type
Posted: Fri Jul 26, 2019 10:16 pm
by 95naSTA
Yep definitely on all points. It's been an awesome car for my wife and has saved us a bunch of money.
I think the only other things I didn't mention in this thread are new tires, brakes and an LCA busing. So we're somewhere in the $1k/year range including purchase price.
Re: 02 Jag X-type
Posted: Fri Jul 26, 2019 10:19 pm
by nos4blood70
That's such a good feeling!
That's how the Bonneville has been for me. Everyone at work drives fancy new stuff and they're paying upwards of $500 a month in some cases. Meanwhile, I usually spend that much on the Bonneville in a year doing random medium sized batches of maintenance.
Re: 02 Jag X-type
Posted: Sun Aug 11, 2019 3:48 pm
by 95naSTA
Re: 02 Jag X-type
Posted: Wed Sep 25, 2019 3:45 pm
by 95naSTA
The fuel pump I put in earlier this year seemed to have an issue with its internal check valve since the car wouldn't hold a prime or hold pressure after the car is shut off. This was making for intermittent and then constant hard starts. I decided to buy another Delphi but return the old one (Amazon) and put it in before the car got shipped to Cali. On first start up it help prime and the hard starting went away. Then it came back slowly so I shot gunned some parts at it before it left. It's a return-less system with a fuel pump driver, fuel rail pressure senor and no FPR. I shot gunned the module and sensor. I also opted to do the battery since it's old and had died over the past winter.
The hard starts are coming back but now they're 3k miles away from me. The wife and car are in Cali and I'll still be based in Philly for a while. I'm not looking to try a 3rd pump and from a non-OEM supplier at that. It's not worth the effort on a borrowed garage floor without my tools. A buddy suggested that if I can safely pinch the fuel line to do so with the car running then key off and see if it changes the bleed-off characteristics at all. If it doesn't, it's leaky injectors. But I'm not convinced that's the issue since the car runs great and there's no stumbling when it starts.
On return systems people use external in-line check valves when their pump check valve fails. On a returnless system you can't do that since it'll trap fuel at the rail.. which can heat and over pressurize. There's a point where the injectors won't open if there's too much pressure built up.
I thought why not put a check valve (1) in with a pressure regulated bypass so that the rail pressure can bleed off? It's the same concept as a return system but the bypass would have a FPR and an additional check valve (2)(opposite direction) to bleed off any pressure trapped by the first check valve. The second check valve in the bypass loop would keep the wrong side of the FPR from being pressurized as well. Ideally you want the check valve close to the tank but I didn't feel ok with having a bunch of additional connections and a FPR exposed to rocks etc. under the car. There's a nylon supply line in the engine bay that goes to the rail and is removable with quick connects. I'm going to build the check valve/ FPR bypass scenario from a spare line and bring it with me to install when I get out to Cali next. This will also allow me to go back to stock in 10 mins if need be. Everything is ordered. I stayed away from no-name Chinesium FPRs and check valves mainly because it's the wife's car. I could have saved $80 by using a stock FPR of some sort but I didn't like the idea of dead heading the FPR when the pump pressure is higher than the potentially lower stock FPR set point. The 2nd check valve on the outlet side of the FPR would be shut from supply pressure. With a good adjustable FPR, I can adjust it so it'll bleed down when the residual rail pressure exceeds the max running pressure (key off).
It'll be a neat little mini project. I wish I had the time before to think of and execute this because it wouldn't take very long. For now the car takes a couple extra cranks to start but starts every time. Hopefully the stock 80k mile starter hangs out till I move there.
Otherwise the car made the transit relatively unscathed. There were a mess of new scratches on the roof but I buffed it all out by hand. The paint on this car is the most forgiving I've ever touched.
Re: 02 Jag X-type
Posted: Sat Oct 19, 2019 9:21 pm
by 95naSTA
So, the check valve fuel pressure regulator bypass setup works. Fuel pressure is doing exactly what I want now. It primes, holds, has good working pressure, holds pressure after the engine is off and the FPR is set to just above running pressure so it can bleed off when required.
Re: 02 Jag X-type
Posted: Sat Jan 23, 2021 3:40 am
by 95naSTA
Back in late December '19 the AEM FPR started to leak where the diaphragm is held in place between the 2 FPR body halves. There was no visible damage to the diaphragm when I took it apart. It may have been as simple as the allen bolts loosening. I've read that's a common failure on aftermarket FPRs in general. I decided to replace the FPR with a pricier Aeromotive unit, p/n 13109. No issues one year and 8k later.
It's been pretty good overall, just oil changes, a set of tires and an alignment recently.
After the last oil change the car smelled like it was burning oil from the engine bay after long drives. I'm fairly certain it was just the o-ring on the CPS so I replaced it. I also noticed a few connection points around the thermostat housing were seeping and the assembly would need to be replaced eventually. Well, the overflow tank started to leak a week or so later and that prompted me to get those leaks taken care of at the same time.
The upper hose assembly Jag sells comes 2 upper hoses, an upper tube, thermostat housing with seal to the engine and thermostat. In my case the seal to the engine, thermostat to housing seal and thermostat to oil cooler hose connections were seeping. Jag only sells the thermostat to oil cooler hose/hard line/hose assembly for ~$150 and URO sells just the rubber hoses + clamps for ~$50. I don't really trust URO and didn't want to spend $150 for 6" of hose and an aluminum tube that doesn't need replacing. When the upper hose assembly arrived I measured the thermostat flange, looked up hoses with the same ID (1.42ish") on Gates' website and found a simple EPDM hose I could cut to fit. It's $12, 2 feet long and works perfectly.
The process is pretty simple to replace the upper hose assembly with a couple of exceptions. The first problem I ran into was the 2 thermostat housing studs from the engine point the housing right into the driver's side fan. I couldn't remove the housing without taking out the top stud. After that, it slid out easy. Kind of dumb but whatever. The other issue I ran into was the bracket that sandwiches the thermostat housing to the engine interfered with raised sections on the new housing. I removed some material from the bracket with a mini belt sander to clearance it. I honestly removed a little more than I needed but it works. I'm not sure if this is an '02 MY thing or why it would have changed.
Here's the modified bracket, modded bracket on the old housing, and modded bracket on the new housing:
Before/after:
Re: 02 Jag X-type
Posted: Mon Jan 25, 2021 8:44 pm
by Sirius
95naSTA wrote:...When the upper hose assembly arrived I measured the thermostat flange, looked up hoses with the same ID (1.42ish") on Gates' website and found a simple EPDM hose I could cut to fit. It's $12, 2 feet long and works perfectly.
Once again, the interweb pays for itself.
Nicely done.
Re: 02 Jag X-type
Posted: Wed Jan 27, 2021 3:43 am
by 95naSTA
Yessir. Thanks. I was happy I found something because it's a year/make/model nightmare otherwise. I never go to a parts store without a part number.
Re: 02 Jag X-type
Posted: Wed Feb 03, 2021 4:28 am
by 95naSTA
Sometimes it's the little things.
Re: 02 Jag X-type
Posted: Wed Feb 03, 2021 10:55 am
by Sirius
Did you repair it or replace it?
Re: 02 Jag X-type
Posted: Wed Feb 03, 2021 7:12 pm
by 95naSTA
I went to pry it out to fix the spring and the 19 year old plastic started to crack. So I found a pair for cheap on ebay and replaced them. The pair I got cost as much as the closest single and they're less faded than the originals so they match. That was unintentional but it worked out.
Re: 02 Jag X-type
Posted: Mon Mar 15, 2021 10:01 pm
by 95naSTA
We decided to take a family trip with this to the Laguna Mountains about an hour away this past weekend to be snow tourists. Even though the roads were basically clear, the condition was R2, or 4wd with snow tires (or carry one set of chains) required. The X-type is AWD with a viscous center coupling, new good all seasons and has generally kicked as s in the snow back in PA. So, I only really had to worry about other people.
Now that we're carting around our son in the car, it's another layer of nostalgia. My parents took me to my HS graduation in this car when it was new in '02, it was my wife's 1st car, it's seen 2 coasts, we took our son home from the hospital in it and now we're using it for small family trips. I feel like cars seeing that type of multi-generational use is rare anymore and it'll be cool to look back on.
Re: 02 Jag X-type
Posted: Tue Mar 16, 2021 9:12 am
by Sirius
Little dude looks right comfy all papoosed up! Someday he'll make his own snowman. Maybe he'll drive the Jag to his prom - the way you treat cars that thing will still be around then.
And I see the barbed-wire fence didn't deter anyone from getting out there in the snow. LOL!!!
Re: 02 Jag X-type
Posted: Tue Mar 16, 2021 3:58 pm
by 95naSTA
Haha, we'll see on how much longer. It didn't escape the northeast without some rust underneath.
There were no trespassing signs all along that fence too. Lol. Snow rules = no rules.
Re: 02 Jag X-type
Posted: Thu Mar 18, 2021 2:19 pm
by Sirius
95naSTA wrote:There were no trespassing signs all along that fence too. Lol. Snow rules = no rules.
In the modified words of Dark Helmet, "Eh...trespass
THIS!"
Re: 02 Jag X-type
Posted: Sat Mar 27, 2021 12:54 am
by 95naSTA
This one was pretty annoying but my stubborness prevailed.
The driver's side rear door handle started to stick recently. I blew white lithium grease at the hinges as best as I could but it didn't help much. Today it was at the point where the door wouldn't latch after it's shut unless the handle was manually shut from the outside.
When I took it apart it was obvious that the hinge shaft had rusted and it's the source of the binding. The shaft rotates with the handle but the shaft also rotates at either side inside the plastic ears connected to the base. I tried to poking and prodding around the to areas the shaft rotates while dousing with white lithium grease and rotating the handle from the base. I did this multiple times no change. Then I tried penetrating oil with the same result.. I tried drilling down to the shaft in between where the handle and base plastic ears meet on the hinge and dosing that with penetrating oil but still no luck. Finally I decided to drill down to the shaft in the middle of the plastic ears they rotate in, blow out the debris with brake clean and then soak those holes in penetrating oil.. and after some rotating of the handle, it worked. It was finally able to spring back on it's own. I blew some white lithium in those holes after that, worked it around a ton then slapped grease over the holes and all over the hinge to finish it off. I guess worst case, if I couldn't find a color matched replacement, I could have replaced the shaft itself. But, that's a messy process and leaning a lot on 20 year old plastic. I was happy to fix what I have.
Re: 02 Jag X-type
Posted: Mon Mar 29, 2021 10:18 am
by Sirius
It's always better to salvage parts that came with the car, I think. With the old iron we tend to have, sometimes that's more of a necessity than a desire.
Re: 02 Jag X-type
Posted: Sat Dec 11, 2021 8:49 pm
by 95naSTA
This car came home with a misfire and loss of power a few days ago.. My wife needed to drive it about 75 miles the following day. This was good or bad timing depending on how you look at it.
I pulled codes and it had a bank 1 misfire. I was too lazy to confirm what bank was 1 but hoped (wrong) it was the front bank. I pulled the airbox and bulb tested all 3 coils. They where all fine. I got the google machine out and confirmed bank 1 was the rear.. Since the intake manifold blocks all 3 rear coils there's no quick way to test them while the engine is running. So, I pulled the IM, swapped the coils front/rear then bulb tested the coils which were previously in the rear. Turns out the rear center, No. 3, was dead. I'm not one for aftermarket ignition products but given the circumstances I picked up a Car Quest coil locally. That fixed the problem for now. I picked up used OEM coils afterwards I'll test resistance on and swap in at some point. I was actually able to get this all done from pulling codes to test driving in about 2 hours. That's not lightning speed for my mechanic buddies but it's plenty fast for me.
Re: 02 Jag X-type
Posted: Mon Dec 13, 2021 11:03 am
by Sirius
Didn't realize you still had the Jag.
Re: 02 Jag X-type
Posted: Mon Dec 13, 2021 10:21 pm
by 95naSTA
Yep, going on 6 years now as my wife's DD. It's sitting at 103k miles now (from 67k) with about 20k of those miles being from Cali. It wasn't cheap to ship it to/from Cali but likely cheaper for something comparable with an unknown service history.
