Speed Daddy Headers!
samples08
88,000k
Re: Speed Daddy Headers!
Post by samples08 »
Double posted again :dontknow: this time on my laptop o well ignore this one 2
Member #3848
2002 Black Bonneville SE Sold But Not Forgotten
2002 White Bonneville SSEi Project car
samples08
88,000k
Post by samples08 »
ah okay i didn't have them at the view so i didn't realize how short the connection was on the backside, i was hoping there was enough to weld some onto, to make it longer to add the connection, and i can't weld im going to have to get it professionally done that's why i was hoping i could cut the factory one's and take them to a shop and then when and if i ever needed to remove the crossover pipe it would just be 4 bolts, and it would give it that awesome factory look to help add to my sleeper appeal. (and like i always tell my wife i know no-one will ever see it but me, but i guess that is gone o well). now that i have you on my post is there anything else i need to pickup to make this easier i got the w-body dipstick and while attempting to get it i did research to make sure i picked up the right one now all i need is the gasket type connector that goes on the stick.
Member #3848
samples08
88,000k
Post by samples08 »
Should i heat wrap them? or atleast the crossover pipe since its directly under the intake tubing?
Member #3848
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
It isn't necessary, but you could if you wanted to.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
samples08
88,000k
Post by samples08 »
Okay sounds good haro one more question any idea where I could pick up a new gasket for the transmission dipstick or the name of it so I can get a new one?
Member #3848
haro1225
Post by haro1225 »
It's just an O-ring down there.
-Ryan
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
ACDELCO 1259475
MattStrike wrote:ACDELCO 1259475
I have a bin full of new ones of these if you want one for cheap.
samples08
88,000k
Post by samples08 »
how much Harofreak and while i have your brain to pick now anything you would like to add to help this go easier im sure you've done this atleast once.
Member #3848
I can throw one in for free with any other parts order, otherwise like $5 shipped.
My advice, do it on a lift. If you don't have a lift, pay someone to do it, lol!
samples08
88,000k
Post by samples08 »
Bahahaha well when I get closer to installing them, I'll order one and sadly no lift but I have ramps so hopeful that'll help a little bit.
Member #3848
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
Surprised no one has welded on Vband clamps for the X-over.. Leak free and come off with one nut... I was going to do that to a set before i found a Plog for next to nothing and decided not to do headers..
http://www.siliconeintakes.com/dsm-inte ... 05a2b34bf0
Shane "RedZMonte"
2004 Z16 Z06: Virgin
