Introducing my 98 SSE. And previous rides.
- techweenie
- SSE Member
- Year and Trim: 2004 GXP
Re: Introducing my 98 SSE. And previous rides.
For the tie rods, do you have a remover tool? It has jaws that fit over the steering knuckle and a bolt that drives the pin out. You can rent them at auto zone. Keep the nut on the pin so it doesn't go flying out.
2004 Bonneville GXP Greystone Metallic - all stock
2002 S10 ZR2 - my favorite truck in the world
1998 K3500 CCLB - motor rebuild in progress, future mud truck
1994 S10 Blazer - 5" lift, narrowed ZR2 rear end, 32x11.5 tires, parting out due to overwhelming rust
- 98SSE
- Posts like an LN3
- Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
I can get the actual outer tie rod loose from the knuckle I just can't break it loose from the inner tie-rod. Mine also appears to not have a jam nut like most, looks factory still. If there is a trick I'll try it, but if not I might cut the tie-rod end off and replace both inner and outers since I've got a inner removal tool.
"Big 3", Tint
"Big 3", Tint
- 98SSE
- Posts like an LN3
Little update today. Finally got around to installing my ZZP shift kit in my car to cure my shudder problem when taking off. It was successful, no more shudder and shifts are nice and smooth. For a daily driver work car like mine this was more that sufficient as far as firmness goes. If your more for neck snapping shifts then I would have added the extra spacers the kit included. Install took about about 2 hours with me working like a turtle, very straight forward. All in all pleased with the purchase. I still curse GM for never putting a drain plug in these...
Pan off and accumulator and filter out.
Pan after 20k since last filter/fluid and 173k on the clock.
Accumulator
Accumulator apart.
2 of the shims supplies (1 inch and 1/4 inch) the others were used (3/4 and 1/2 inch)
Everything all back together and cleaned up.
Accumulator
Accumulator apart.
"Big 3", Tint
"Big 3", Tint
