Page 2 of 2
Re: Camshaft...again..
Posted: Thu Mar 20, 2014 3:03 pm
Just the nature of using a production engine for non-production intended uses. There's more than one way to skin a cat, this is just the easiest way...
Posted: Thu Mar 20, 2014 3:27 pm
by Tsimms55
Hey just a quick question, were any of you able to cam you car while leaving the engine in car? I've been looking into a cam right now since im top swapping as well and just wanted to know
Posted: Thu Mar 20, 2014 3:35 pm
by Jfridge92
Tsimms55 wrote:Hey just a quick question, were any of you able to cam you car while leaving the engine in car? I've been looking into a cam right now since im top swapping as well and just wanted to know
http://www.pontiacbonnevilleclub.com/fo ... 10939.html
techinfo is your friend :beerchug:
Posted: Thu Mar 20, 2014 3:50 pm
by Tsimms55
Thank you!!!!
Posted: Thu Mar 20, 2014 10:26 pm
by MattStrike
I'm not convinced that the OEM 11-link LG3 chain isn't up to the task of running on 150# valve springs.
It's almost 2x's as wide as the L67 8-link chain. The pins are 2x's the diameter of the 11 link chain.
At this point, WTF not? http://www.jegs.com/i/Milodon/697/13800/10002/-1
Posted: Thu Mar 20, 2014 10:55 pm
by 2000Silverbullet
A real whiner with that gear drive!
Posted: Thu Mar 20, 2014 11:12 pm
by yourgrandma
The OR pushrods are also nice to help keep the oil in the places it really needs to be. Like the crank bearings.
Posted: Fri Mar 21, 2014 10:29 am
by SSEiMan01
Can, can I have the NIC? 8-[ :offtopic:
Posted: Sat Mar 22, 2014 6:39 pm
by MattStrike
So I've been thinking about this, I'm going to try to make a cam adapter for the LG3 set. If that works out then there are several good set of double rollers for the RWD version in the $60-$80 range.
Posted: Sat Mar 22, 2014 6:58 pm
by Zeik75
What exactly is the difference between the two?
Posted: Sun Mar 23, 2014 10:43 am
by MattStrike
LG2/LG3/LD5 are meant to fit a cam with a distributor gear even though the LG3 did not get a distributor. The center hole in the cam sprocket is very large, they have a different cam sensor magnet and don't have a balance shaft. The OEM chains for them are 11 links, the pins are 2x's the diameter and about 5/8" wide or so. From what I can tell the 11-link chain was good up to the 130# valves and the crank gear doesn't need to be machined on the roller sets. Center to center from crank to cam is the same between them, which when I had them side by side looks like has not changed in the L67.
