Catalytic Converter that Won't Throw a Code
mrwildroot
Year and Trim: 2000 Bonneville SE
Re: Catalytic Converter that Won't Throw a Code
Post by mrwildroot »
flywelder wrote:Thanks MW!
MW, would you be able to tell me where the MAP sensor and the purge solenoid is, The PCV, and what the round cylinder is that is on front of the intake plenum , and close to the engine oil fill neck, and has vacuum lines going to it ( i think 3 lines.)? on my SE with 3.8L V6 with no super charger.
Thanks
http://www.greatautohelp.com/sensor-location/3800.html
Hope this helps.
MW
flywelder
Year and Trim: 2005 Bonneville SE with V6 3800 engine series 2
Post by flywelder »
Yes this helps tremendously!.. Thank you so much!
Now I have to discover why and what is causing my car to throw a sporadic EVAP code, even though neither I or the mechanic can find any leaks or defective parts! still because of this EVAP code. I am unable to get the car to pass the NC DOT inspection! Frustrating!
