Misfire . . . AGAIN!
dayton.reed
Re: Misfire . . . AGAIN!
Post by dayton.reed »
Gasket for throttle body wasn't in stock, so I just changed the fuel filter to see if it wouldn't make another incremental increase in performance. It misfires a tiny bit worse now. :(
oh ya, and I smell like gas now. :-$
2000 SSEi, Napa Belden wires, Monroe rear shocks conversion, Dexcool delete
2000 SSEi with custom glass, body, door, and light kit
vogie01
Post by vogie01 »
Try to get your hands on a MAF that you know is good. Whether it be a junk yard, a friend or relative with a 3800 or buy one. If it is bad cleaning it is going to do you no good.
That way you can at least eliminate that possibility for sure. A bad MAF can make the car do some weird stuff that will make you think other wise. I did the same thing and finally changed it and fixed the problem.
mackryan7512
Year and Trim: 2004 Bonneville SLE
Post by mackryan7512 »
Did you ever solve this issue?
DD 2004 Bonneville SLE
