Installing Rokford Fosgate 3sixty.1 in 2000+
95SLE
Year and Trim: 2004SLE
Re: Installing Rokford Fosgate 3sixty.1 in 2000+
Post by 95SLE »
Simply use the wiring diagram from the FSM to locate which color wires control what in the rear and tap the rear speaker leads.
I do not believe that all of the wires are in one place at the rear of the car in a non-Monsoon equipped Bonneville. The wires go from the HU to the speakers. Can anyone verify that what I just stated is true?
I plan on replacing all six of the speakers. I do not plan on installing a separate subwoofer.
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
Red Rocket
Post by Red Rocket »
95SLE wrote:Simply use the wiring diagram from the FSM to locate which color wires control what in the rear and tap the rear speaker leads.
My car has the Bose system. What system do you have and what does it consist of? That will help out immensely. Do you have a factory amp behind the rear seats? If so, you'll want to tap into the wires on that.
Audio: 12" Alpine Type R in 2.3 cu. ft. box tuned to 31 hz, Audiobahn A8000T, Rockford Fosgate 3sixty.1, Kicker wiring
Mods: Cross drilled and slotted rotors, hopefully more to come soon
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
Tom has a 6 speaker Delco system in his SLE. No amp
Red Rocket
Ok, that helps.
All of the factory HUs from 2000-2005 are the same. They all use the Dock N Lock system so there are no wires. If you use the DAL connector, I'm pretty sure you will lose the functionality of your chimes and such because the radio is not plugged into dock connector. Only an interface device would compensate for that. If you plan on replacing the speakers and going aftermarket, just tap into the speakers since you will everything apart or run your own wiring. It's going to be difficult for your car because you don't have an easy place to tap your speakers besides in the rears.
95SLE
Post by 95SLE »
Red Rocket wrote:It's going to be difficult for your car because you don't have an easy place to tap your speakers besides in the rears.
That is why I was planning on buying a male and female DAL connectors, bridging all of the pins except the speaker cables as a straight through connection and sending the speaker leads into the sound processor.
My concerns lie with the clearance space behind the HU to support the DAL cheater cable. I might have to pick up the speaker output in the door as you are suggesting.
COTM April 2007
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
it is easy to tap into the speaker lines in the kick panels of our cars. There is a big wiring harness in each kick panel that has the front speaker cables connected to it.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
Red Rocket
I really don't think you are going to have enough room unless you start cutting out that area. I'm just go with tapping the speakers themselves.
