Slow starting/long crank
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: Slow starting/long crank
Post by MKMike »
Oldsman003 wrote:has anybody found an answer for this? same symptoms. curious as to what the issue could be. i also have replaced numerous parts in the past little while
If you start a new thread and list exactly what you have done to try to correct the problem, you'll get more replies and better help, in all likelihood.
Also specify whether it is cranking normally and not starting right away or cranking slowly and starting after a delay.
