problem with bonnie only when u try to accelerate
savagecowboy_69
- Year and Trim: 1992 bonneville sse
Re: problem with bonnie only when u try to accelerate
did a voltage test across the tps to see if the voltage varied with throttle it did checked the iac voltage checked out on that. it idles right where it should in between 975ish and 850ish no mil lights i can only check the resistance on the secodary wires and the coils i dont want to disconnect the secondary cables with the car running.
92 sse that is being restored so it can eventually be turned into a show car
savagecowboy_69
btw is there any where tha i can purchase just the fuel injector tips,little plastic things that hold the o-rings on, without buying the entire injector
savagecowboy_69
JMAEDLO27
- LE Member
- Year and Trim: 1997 buick lesabre custom
make sure throttle position sensor was installed correctly... very easy to put in incorrectly. Start with sensor turned far right, then turn left till screws line up
savagecowboy_69
it was, it got adjusted till the code saying [low tps voltage] dissapeared
savagecowboy_69
well the bonnie is gone but i miss it already thanks for all the help u guys gave me hopefully i will be able to get another one soon that one just had to much money put into it and i still had way more to dump into it so it had to go, and again thanks for all the help.
