My Snowmobile!!
SSEiMan01
Re: My Snowmobile!!
Post by SSEiMan01 »
yonkerse wrote:I prefer my hoodie to be washed and ironed when received! :P
wake wrote:What's an Iron? Does the storm drain count as a wash? :poke:
James May wrote:Hello.
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
HAHA, he will probably try ironing it with the front tire of the windstar.... :roll:
Eric
A few mods..
SSEiMan01
Re: My Snowmobile!!
Post by SSEiMan01 »
yonkerse wrote:HAHA, he will probably try ironing it with the front tire of the *shoot* star.... :roll:
^Fixed it for ya! ;) No, it won't do burnouts with the trans slipping like it does. :btruestory: :bhuh:
He's more likely to iron it with the knobby tires on the S10. :P
wake
Re: My Snowmobile!!
Post by wake »
the TKOs on the s10 would tear thru his hoodie like a hot knife thru butter
i was throwin snow about 30 feet with em yesterday :btruestory: :twisted: :banana:
haney07
Year and Trim: 2002 Pontiac Bonneville SE
Re: My Snowmobile!!
Post by haney07 »
dang I didnt get to vote for you! awesome pics though! Nice job!
Miss Haney
2002 Pontiac Bonneville - Tinted Windows, 18" Chrome Wheels, Rockford and Fosgate Subs
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
haney07 wrote:dang I didnt get to vote for you! awesome pics though! Nice job!
Thanks Lauren! Hope your car is still treating you well! Looking forward to hitting up the cruise this year in G.R again! :banana:
Eric
A few mods..
G1eitz
Year and Trim: 2003 ssei
Re: My Snowmobile!!
Post by G1eitz »
What are the switchback lights on your car? I'm not very familiar with switchbacks... And is your led lightbar a solid thing on the inside or a flexible light bar? How's it wired up
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
G1eitz wrote:What are the switchback lights on your car? I'm not very familiar with switchbacks... And is your led lightbar a solid thing on the inside or a flexible light bar? How's it wired up
The switchbacks are as simple as this..when your parking lamps are on, they are the regular blue color...as seen here:
Once you put your turn signal on, the color switches and blinks Amber..as seen here:
The LED strips are flexible strip that have adhesive on the back. They simply just stick to the housing once the head light is separated. I ran my own wiring to them with a switch so I can control when they are on or off.
Eric
A few mods..
G1eitz
Re: My Snowmobile!!
Post by G1eitz »
Where did you get the led strip? And can you put the switchbacks in how it is or does it need an hid conversion kit?
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
G1eitz wrote:Where did you get the led strip? And can you put the switchbacks in how it is or does it need an hid conversion kit?
My car has had a complete LED conversion..all my interior and exterior lighting has been changed from regular bulbs to LED's. All the bulbs were purchased from www.v-leds.com. They stuff isn't cheap, but I have never been disappointed in anything I have purchased. They also have great customer service and have replaced any defective product I have encountered with no questions asked.
The Switchbacks were simply plug and play. They didn't require any changes to anything. They are a little long for the housing and take some patience installing, but nothing terrible!
Eric
A few mods..
G1eitz
Re: My Snowmobile!!
Post by G1eitz »
Do you remember a link or where you got your switchback bulbs? And also is this the one you got for the led strip? http://www.v-leds.com/Interior-LED-Bulb ... 00654.html
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
Yes, that is the LED strip I used for the mod.
Here is the link for the switchbacks. I see they are still on back order...I waited a couple months to finally get mine...must be a popular item..
http://www.v-leds.com/Exterior-LED-Bulb ... 6-1-2.html
Eric
A few mods..
G1eitz
Re: My Snowmobile!!
Post by G1eitz »
sorry for all the questions but did you just use 1 of those led strips per light or multiple? and do you have load resistors on the switchbacks?
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
I used one 24'' LED strip per head light. Those LED's are designed to be broken off if needed between the lights, but they become real undependable once broken, so I just laid the complete strip in the light.
I do have load resisters on my car, only because I'm running LED turn signals in the rear as well. I installed my switchbacks first, and didn't need the load resistors.
Eric
A few mods..
Re: My Snowmobile!!
yonkerse wrote:I do have load resisters on my car, only because I'm running LED turn signals in the rear as well. I installed my switchbacks first, and didn't need the load resistors.
So do you need to run load resistors to have these things up front in the turn signals? Or are the load resistors necessary only for the back? :dontknow:
SSEiMan01
Re: My Snowmobile!!
Post by SSEiMan01 »
We stuck a switchback in my car when he was here, IIRC, you don't need load resistors on the front.
yonkerse
Re: My Snowmobile!!
Post by yonkerse »
This is correct. If only replacing the fronts to LED bulbs...switchbacks or not...you don't need load resistors. Now, if your replaced the front and rear turn signals to LED, then the overall line resistance drops since the LED's require less power, requiring load resistors.
Eric
A few mods..
