Warning chime is driving me nuts!
RJolly87
Re: Warning chime is driving me nuts!
Post by RJolly87 »
Oldsman003 wrote:that chime is super annoying, my current lss and my old ls had this same problem. that *dang* chime will just start chiming and wont stop. both of mine i went under the dash i believe on the passenger side hidden by the hush panel if you look way up in there you can see a small speaker, look real hard that is the chime. i disconnected both of mine. best thing i ever did, good luck.
I must express the need to use caution when doing this maneuver. In the older gens, the chime module may be tied to and control multiple systems. I know for sure the PA has the chime module tied to the power steering, and I think the cruise control is tied to it as well.
It is usually better just to fix the problem, unless you drive a '94 Regal and are annoyed by the dinging when you leave the turn signal on too long, then maybe...
I also mirror the thoughts on old threads too, despite adding to the mix....
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
It is annoying in the same way that any alarm is annoying---it is meant to alert you to a problem.
Hopefully, you're a hypervigilant person who watches the gauges and lights like a hawk.
My better half is in the habit of driving cars until there is practically nothing but fumes in the gas tank.
The dinging is good for compelling a stop at a gas station before it runs out of gas.
Yes--it has happened before---in other cars but not in the Bonnie.
Really pissed me off to have to walk to a gas station because the driver ignored the fuel gauge.
If you read why my chime was going off, you'll see how it could be unwise to ignore it or disconnect it.
It looked exactly like the MC reservoir was full.
If I hadn't been nagged by the chime and warning light, the result would not have been good.
RJolly87 wrote:
Oldsman003 wrote: It is usually better just to fix the problem, unless you drive a '94 Regal and are annoyed by the dinging when you leave the turn signal on too long, then maybe....
My 98 SE does this, which I like. Saves me from having to tell my beloved to shut the freaking signal off, when left on.
Oldsman003
Year and Trim: 1998 Oldsmobile LSS N/A 330k
Post by Oldsman003 »
the chime is not tied to anything other than the warning idiot lights in the car, it is only there to tell you your door isnt closed, low on fuel, etc... it is NOT tied into your power steering or anything mechanical like that. my oldsmobile hasnt had it hooked up for 200k miles, no issues... it nodes well for me because in my olds there isnt a low fuel light nor is there a chime to tell me i have low fuel so that doesnt bother me. you should watch all your gauges and lights anyways and not just drive and drive until the car stops. and if im not mistaken it is a short in the ignition switch that causes the chime to chime constantly. unless you want to pull the column apart and replace it, disconnect the chime and save yourself some money and hours of time.
1998 Oldsmobile LSS
3800 Series II N/A 360k
4T65E Stock 360k
2005 GXP
Rebuilt Northstar
4T80 144k
RJolly87
Post by RJolly87 »
Oldsman003 wrote:the chime is not tied to anything other than the warning idiot lights in the car, it is only there to tell you your door isnt closed, low on fuel, etc... it is NOT tied into your power steering or anything mechanical like that.
In your case, this is probably true.
In my case, it's not. Hence the warning.
jonnevilleSSEi
Year and Trim: '97 SSEi
Post by jonnevilleSSEi »
My Chime stopped when I repaired a brake line. The braking system was losing pressure and there was "supposed to be" a warning light on the dashboard but that failed to illuminate. So in my case the annoying ringing did represent something to repair that could have had severe consequences.
Unfortunate update but happy ending: Even after the tightening which stopped the chime, one of my brake lines blew out and I lost my power assist. Good time learn about that brake issue is on the PA Turnpike when RUSH HOUR traffic suddenly stops and you have virtually no brakes! P A N I C ! ! time. I'm alive, Bonnie is lucky to have only a small poppable dent. Could have been a billion times worse - BRAKES are important.
Last edited by jonnevilleSSEi on Sat Nov 28, 2015 7:27 pm, edited 2 times in total.
'97 SSEi, Majestic Teal / Beige interior, Bose, HUD, iPod ready! - SOLD! :sad: Check it out!
1oldman
Post by 1oldman »
Oldsman003 wrote:the chime is not tied to anything other than the warning idiot lights in the car, it is only there to tell you your door isnt closed, low on fuel, etc... it is NOT tied into your power steering or anything mechanical like that. my oldsmobile hasnt had it hooked up for 200k miles, no issues... it nodes well for me because in my olds there isnt a low fuel light nor is there a chime to tell me i have low fuel so that doesnt bother me. you should watch all your gauges and lights anyways and not just drive and drive until the car stops. and if im not mistaken it is a short in the ignition switch that causes the chime to chime constantly. unless you want to pull the column apart and replace it, disconnect the chime and save yourself some money and hours of time.
I know this is an old thread, but that is not a good idea. The chime can save your life. Find out what's causing it.
willwren wrote:Don't underestimate that chime. It could (and usually is) a very serious indication of a problem. Typically a master cylinder problem is indicated by that chime. By the time you hear it, you may not have much time left before you wreck.
Carefully check the braking system for leaks, fluid level, etc. Check ALL fluids, including the washer reservior.
freneticburn wrote:Do you just rip the batteries out of a fire detector when there's a fire in the house too? :poke:
renchjeep wrote:
willwren wrote:The car in question is in for serious problems in the very near future.
Perhaps the driver as well!
:roll:
Very good responses jmo - BC
94GreenMachine
Year and Trim: 1994 SSEI
Post by 94GreenMachine »
My car did the same thing, I even went so far as to remove the parking brake chime. Turns out my brake fluid reservoir was empty. It was driving me crazy. Perhaps give that a look and see what's up.
