Page 2 of 2
Re: 95 Pontiac Bonneville SSE almost 300k, mostly stock
Posted: Wed Apr 13, 2011 12:55 am
by BFF_Larry
ahh maybe faulty?
Posted: Wed Apr 13, 2011 12:59 am
Idk, but that's a risk you don't want to take, lol.
Posted: Wed Apr 13, 2011 5:33 pm
by Bing
That's the only point I was trying to make. Weather it's the best battery in the world and all self contained you should always have another safety net on board. Just trying to keep you and your passenger safe. :wink:
Posted: Thu Apr 14, 2011 1:08 am
by BFF_Larry
tomoro after school, im starting the run of 0/1 wire and hopefully my alt is in
Posted: Tue Apr 19, 2011 2:35 am
by BFF_Larry
update:
just finished running the 0 gauge wire, did the Big 3, and ran all power with 0 from each battery - amp.
took awhile to do but so much easier to do things with the seats out. :]
but the hardest part was soldering the terminals. that was the most time consuming and frustrating thing of especially since it was my first time doing so. but it became easier as i kept soldering.
I used resin core , a vice grip. razors, elec tape, and a mini torch.
waiting for the alt from mechman
Posted: Fri Apr 22, 2011 5:19 pm
by 99bonnieSE
Ahhh the mechman alternators
Nice choice!
Posted: Fri Apr 22, 2011 7:00 pm
by BFF_Larry
it was a Iraggi alt but they rebuilt it and it has a warranty under them now
Posted: Thu May 05, 2011 11:45 pm
by BFF_Larry
ohh, the alt came in today, and so did the decals i got off ebay that say "got bump?"
pics in alittle
Posted: Fri May 06, 2011 6:40 pm
by lunchboxx
Looks good as long as you never have more than one passenger...
That trunk leak you have is more than likely a leaking tail light assembly. Do a search on here for ideas of how to do a permanent fix for that.
Posted: Sun May 08, 2011 4:27 am
by BFF_Larry
heres the alt that came in
Irragi HO alt, rebuilt by Mechman
my gf's tryin to pick it up
Posted: Sun May 08, 2011 4:33 am
by BFF_Larry
new decal
back....kinda crooked
front..
Posted: Mon May 09, 2011 4:30 am
by BFF_Larry
box for 4 15s done.
3 cu^ft each
Posted: Mon May 09, 2011 6:52 am
by 99bonnieSE
WHEW..... thaats gonna be loud.
Posted: Tue May 10, 2011 7:51 pm
by 88bonnsse
this should sound nice. im not a fan of audiopipe but i just pulled the system out my 95 sle and im sure most of you veteran members rember my ststem..
4 15'' L7 subs in custom ported box thru back seat, 2 kicker kx2500.1 amps, 2 kicker kx650.4 amps, 4 10'' ev's and 4 8'' beymas, 300 amp iraggi alt from dom, and 4 deka 9a31 ( intimidator ) batteries..
you need to brace the *shoot* out the box for the 4 15'' kickers no matter how big the port is, or you will get plenty of box flex which will lead to poor quality sound and less pressure.. and i hope you used 1'' mdf...
and i gota see how you fit 12 cubed box in your trunk.. i built the biggest box i could fit sorta and it was only 9 cubes total for all 4 subs...
got any pics..? box dimensions, port dimensions, tuning ?
looking nice tho.... :btruestory:
Posted: Tue May 10, 2011 9:08 pm
by BFF_Larry
audiopipe and audioque are like the same, and both are kinda like underground if you ca say that
Posted: Thu May 12, 2011 10:09 am
by 88bonnsse
BFF_Larry wrote:audiopipe and audioque are like the same, and both are kinda like underground if you ca say that
i really have to disagree on that one bud, audioque is made by digital designs. one of thee best if not the # 1 car audio maker in the entire world..
you can never compare audiopipe to audioque.
thats like comparing a supercharged bonneville to a ford escort.. , you just cant compare...lol
Posted: Thu May 12, 2011 1:00 pm
by BFF_Larry
i meant in reviews, there amps are both underrated and are extremely good for the price.
ap amps and aq amps bench tested prove that there underrated
Posted: Sun May 15, 2011 7:11 am
by BFF_Larry
added another Stinger spv44 battery to the back.
getting a third spv44 in alittle while.
trying to build a battery bank ha
Posted: Tue May 17, 2011 1:51 am
by BFF_Larry
got my third spv44 today. finished soldering terminals on. putting it in tomoro.
3x spv44
1x batcap 800
1x Exide Orbital
1x sum 1000cca batt under hood
ha
Posted: Wed May 18, 2011 2:33 am
by BFF_Larry
installin Jensen vm9312 tonite
