I had a chance to look at your logs.
A few things.
I must apologize, I drift in and out of your posts so I loose track of what point your at, again I apologize.
- I notice once you go into PE mode your afr goes way down into the 10's 10.8 & 10'6 for commanded afr. You have some parameters that are causing that. Again, its comanded afr which means this is what the program is looking for.
I'd try to figure out what parameter is doing that and adjust it accordingly.
- As noted by another member the timing advance drops to zero* during the 1>2 shift. so does the IDC's. and your boost drops.
I got a question:
Are you using tuning tips/BKM's (best known methodes) from different people at the same time? there are many good ways to tune, but I'd stick with one at a time until your completely done. Then save the file, then start from scratch with someone's bkm's.
all your part throttle driving looks good, your long & short terms look good.
What I do like is once you enter PE mode your long & short terms instantly go to 0.0. Excellent work. I honestly wouldn't try to ge them any better, move along to something more troubling in the tune. frames 4366your in part throttle commanding 14.7.. frame 4367 yo enter PE mode and the fuel trims dial straight to 0.0. again, nice work.
it all looks good until you commanded afr goes below 10.9~10.8 -ish That's when the KR comes and your pulling timing, IDC's will drop etc. Seen it before, get too much fueling and the engine lays down.
Then right in the middle of all that random KR you shift into second. It looks like your commanding the shift at 6000 rpms or 53~54 mph. At that point your into the WOT parameters in the trans tables. if you want the car to shift based on the RPM's then set the mph slightly higher then the shift rpm and the pcm will shift on the rpm. you don't want the pcm hunting for a shift, taking too long to complete the shift etc.
The same stuff is exihibeted from frames 5305 to 5420 +/ a frame or two.
I'll have to scrounge thru some of my logs to corralate the O2's to actual afr because I use a wideband therefore I loose track of what 890 mv represents.. sorry.
- clean up the shifts.
- clean up the afr in PE mode, its still way too rich.
- also just for logging, instead of spending so much time graduating into 100% tps, step on the pedal... get into it and lets see how the PCM dives into it instead of a gradual increase. Those transitions are tricky for the PCM. I'd just like to see what the PCM does when you got on it all out.
Have you ordered a wideband yet?
I realize you can't import the data into your vehicle interface but at least you'll know for reference.
Looks like good learning.
Can you send me a copy of your current .hpt file, I'd like to see what's causing your PCM to command 10.6 AFR while in PE mode.
Later,
