Intak gaskets done and Running!!
- willwren
- Retired Admin
- Year and Trim: .
Re: Intak gaskets done and Running!!
You ran carb cleaner through WHERE?
94SilverSSEi
68 w/400
The throttle body, just took the rubber part off the air box and sprayed it in there
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
- willwren
- Retired Admin
- Year and Trim: .
Did you know carb cleaner is the worst thing you can do to your MAF sensor? Not only can it crack the plastic that protects the filaments, it can burn them out. You should only use 'sensor safe' intake cleaner on a fuel injected car.
You may have just caused more problems.
94SilverSSEi
68 w/400
Idk. After I sprayed a BUNCH of cleaner through it. It seems to run very very good now. Also I put the bottom oring on the pcv but it didn't seem o have any effect.
Clay
94SilverSSEi
68 w/400
Got it all done Saturday. Seems to run great now by my idle seems high. Like 1000-1500 in park usually around a thousand. Except on first start up it seems to sit at 1500
and in gear it stays a like 900
Clay
- J Wikoff
- Year and Trim: 1992 SSE
Check for vacuum leaks (hissing) and perhaps a reason for the throttle body to not close all the way, like a mal-adjusted throttle cable.
