While tearing apart my now broken engine (see this thread http://www.pontiacbonnevilleclub.com/fo ... =11&t=6911), I found my revised 1.6 HS rockers to be heavily worn after ~35k miles. There's a pattern to the wear too. Intake rockers have very light wear (about as expected), while all of the rockers for the exhaust valves show heavy wear from the roller tip digging into the rocker body. Design flaw?
Intake
Exhaust (if you look close you can see the alternating wear pattern between exhaust/intake rockers)
