Window Regulator Just Broke!
mshipon
Post by mshipon »
Well, I've read all about it on the forum, but now it's happened to me! I was putting up the left rear window in my 2000 Bonneville SSEi on Sunday and "bang"... something snapped inside the door. I'm assuming the regulator wire broke.
I work at a dealership and my price to replace the regulator/motor assembly is $460!!! Ouch!
I went out to ebay and found the following after-market replacement units:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =p3907.m32
A couple of questions...
Are these products acceptable?
Are they direct replacements?
How hard to install?
Any installation instructions out there?
Using one of these products and doing the job myself would save me hundreds. What do you guys think?
Thanks for the help.
Martin
Rusgreim
Year and Trim: White 2000 Bonneville SLE
Re: Window Regulator Just Broke!
Post by Rusgreim »
I have seen forum members recommend those highly, and others have disapproved. I figure, even if it only lasts half as long as the factory unit, thats going to get you 4 years, and save you tons.
I did mine about a year ago (before I found the club) and used an aftermarket unit from a local scrapyard that sells some aftermarket parts. It was $125 and has been fine for me this long. As for instructions, its pretty straight forward. There are instructions on removing door panels on several different threads, but like I said, I was able to feel my way through it even though I'm not super inclined.
Pretty simple work if you ask me, and as for the eBay part, I'd go for it. Thats what I'll be using if I have another one go bad (I almost never use my windows, so its not likely to happen again).
Russell (Rus or Rusty)
White 2000 SLE - 161k Miles
Current Mods - Transgo Shift Kit, 180* Drilled Thermostat, NGK TR55 & Belden Plug Wires, Suspension Energy Endlink Upgrade, "Stock" 12-Way Power Seats, "Stock" Heated Seats, "Stock" Homelink GDO, Cleared Corners, Pins & Dealer Badge Removed, 2002 56I Center Console, Dash Trim, Steering Wheel and Shifter Swap, Auto-Dimming RV Mirror, Pioneer AVH-P4000DVD MP3/USB Headunit w/ Steering Wheel Controls and iPhone Music Interface, Hood Protector, Gutted Airbox w/ K&N Filter.
Mods in Progress - SSEi Inflator with Stock controls, Chrome "Swoopies" (Have rims, need tires)
Future Mods - Viper 5701 Remote Start with Smart Start and 35% Window Tinting
Skippy1827
Year and Trim: 2015 Cadillac XTS
Post by Skippy1827 »
I have installed 2 window regulators in my Cadillac in the coarse of two weeks. They both did the same pop-N'-drop.
They both use the same GM plastic parts that get brittle and crack. They look similar to yours. Mine were easy. I went to Partstrain.com to buy mine. Cadillac wants between 4 and 6 hundred depending where you go. I saved quite a bit of cash.
$60.00 each. I am not happy with how one wobbles going up. I am not sure if I set the window back in wrong, or the part wasn't the best.
I will have to remove the panels AGAIN! to adjust the window.
You can do it
Steve
Modify your own to be better than OEM = http://www.pontiacbonnevilleclub.com/fo ... f=43&t=212
golfyeti
Every available option
Post by golfyeti »
I got mine from Window Motor World Inc who claims that 95% of their stock is OEM, or they have refurbished these to stronger than new. It's been holding up nicely for two years, and gets a lot of abuse form my son.
Check out their site. And the feature product on their main page?... you guessed it... Bonneville regulator! You are NOT alone... LOL
http://windowmotorworld.net/
Mark
The Familyman's Trans-Am
ColoBonne
Year and Trim: 2005 SE 180
Post by ColoBonne »
I'm with harofreak00 on this. The fix works great.
For less than $10 bucks and about an hour to make the part, fixes the prob and it WON'T happen again
Peej9089
Year and Trim: 2000 SLE Bright White
Post by Peej9089 »
The repair in this forum may work great if there is no damage to the cables. My cables were frayed and damaged. So I sent them to Mirror Gaurd to be repaired. They cost about $85 bucks but they are completely rebuilt with new parts and very quick turn a round.
http://www.onetobuy.bizland.com/index.htm I think others on this site have done the same
mshipon
Post by mshipon »
It seems like Regulator USA might be the way to go. Lot's of great testimonials.
Thanks,
Martin
Archon
Post by Archon »
I've repaired regulators with the frayed and damaged cables without problems. They're a little harder to work with, because they can be sharp. The cables are more than strong enough to work with some broken strands, and any kinks straighten out when tension is applied. Deciding to purchase over repair is fine. However, I don't want people discouraged who may want to try it, just because of some frayed cables.
