Fuel filler door actuator push pins
Bonneville'n
Post by Bonneville'n »
Hello, im am looking for the push pins that hold the gas door lock in place? Anyone have a part #? Is this something common at my parts store? Thanks for the help. 2000 Bonneville SSEi
240k, Cleared Corners, Silverstars, Yellow 893 fogs, LED Marker,
Reverse & interior bulbs, L32, Triple Edge
transmission, Intense FWI, N*, GXP Brake & Swaybar Swap, Pacesetters
ddalder
Re: Fuel filler door actuator push pins
Post by ddalder »
The parts diagram doesn't show these as a separate part; they appear to come with the lock (which is no longer available). You may get lucky and find something at your local parts store, but I wouldn't count on it. If I remember correctly, they are kind of an odd size.
harofreak00/Andrew probably has some means to help you out. Send him a PM or e-mail.
I just left mine broken, Andrew suggested that it's not a great design and likely to fail again.
96 SSEi
Post by 96 SSEi »
go to the parts store or gm dealer and see their single clip section - they had many kinds.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
I do have them, PM me.
