P1665, P1676 98 SE
pcw1973
Year and Trim: 98 SE
P1665, P1676 98 SE
Post by pcw1973 »
I have a 98 SE, 285k miles, still runs great. But, evap vent valve and purge solenoid codes are coming up.
I've replaced both, reset computer. Still coming up.
Also p0135 upstream O2 sensor preheater code. Replaced. Still coming up.
Anyone know what voltage and when, I should find at vent valve and purge solenoid connectors?
I have ground on red wires on both. Nothing (0.06V) on white wire at vent valve connector, same on green wire at purge solenoid, when i turn key on, or start.
I'm at a loss. Need *dang* emissions sticker.
Connectors are clean, and look good.
What am I missing?
(Recently replaced: Intake gaskets, upper plastic part of the intake, of course, BOTH O2 sensors, purge solenoid at top front of engine, Evap vent valve below PCM, Power steering rack, battery and cables, fuel pump and sender, fuel filter, pugs and wires)
ANY knowledgeable assistance is appreciated.
My wife loves this car, so do I. We keep it maintained. I want to see her break 300k...
redfury
Re: P1665, P1676 98 SE
Post by redfury »
Look at the wiring. Our Sport trac had the gas cap light come on intermittently and then the evap code for low input. I had previously planned to replace the vent solenoid since they do wear out, but ended up finding corroded wires in the engine compartment . Repaired the electrical connection and it's been fine since. Physically feel the wires. All it takes is for some idiot to probe it once with a piercing tool and not seal it back up and it can corrode.
pcw1973
Post by pcw1973 »
Thanks, I've been over the wires. Still can't find any issues. Curious tho. If a fuel cap could cause the same code, then a leak at the tank could also?
inition
Year and Trim: 1999 Oldmobile 88 LS
Post by inition »
I has a SES from one spark plug with the wrong gap.
Pair of SSEI
Year and Trim: 1997 SSEI 40th
Post by Pair of SSEI »
There are several pieces of rubber hose connecting the purge lines in varies locations. check for holes or splits in hose. I had a problem with the one at the firewall under a hose hold down build into the wheel well. Just rotted away.
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
