Stepper motor and bulb replacement
djdani3l10
Year and Trim: 2005 Pontiac Bonneville SE
Post by djdani3l10 »
i understand the process to replacing the stepper motors,
but how would i install these led's
http://www.ebay.ca/itm/6x-GM-GMC-Steppe ... bR&vxp=mtr
if you can help
let me know
thanks
ddalder
Re: Stepper motor and bulb replacement
Post by ddalder »
You wouldn't. Those are for a completely different cluster where the bulbs are installed in sockets that twist into the back of the housing. The lamps on the Bonneville cluster are very small and are soldered to the printed circuit board. Changing them to LED (although not impossible), is not an overly easy task.
