Car is falling apart, or neglect is catching up to me
xyeLz
Year and Trim: 2001 SSEi
Post by xyeLz »
Not sure which to blame, but recently had to drop $1500 for wheel bearing, tie rod ends, alternator, and a whole crapload of stuff I really shouldn't have done.
Then 2 days later, the car dies in a parking garage. I'm told it's the battery, which is only 2 years old, but makes sense since the alternator was a year old and died and probably put a lot of stress on the battery.
Just wanted to check with you guys to see if all this makes sense so far, logically speaking.
I also need to replace the supercharger tensioner pulley. I just purchased the one off INTENSE and plan to install this myself. A year ago I installed the grooved idler pulley myself, but wanted to see if it was difficult to replace the tensioner as well. The shop is trying to charge $80 for that (really? that's 4 hours of labor).
Black 2001 SSEi | Performance: INTENSE FWI, INTENSE Shift Kit, INTENSE 180* Thermostat, GXP Calipers (custom powder coated), EBC GD Sport Drilled and Slotted Rotors, EBC Redstuff Brake Pads Aesthetic: Debadged | Cleared Front and Rear Corners | Red Rear Turn Signals | Bright White LED Reverse Lights | Black Centerpiece | Black Pontiac Emblem | 35% Huper Optik Tint | GXP Interior (Carbon Fiber Vents and Handle Inserts, Stainless Handles, Shifter, Black Buttons for Windows and Cockpit, Cupholders) | Hood and Rear Quarterpanel Herpes :thumbdown:
DCJREDLINE
Year and Trim: None
Re: Car is falling apart, or neglect is catching up to me
Post by DCJREDLINE »
IMO all of those things (beside the alt/battery) are wear items, you dont mention how many miles the car has on it. To me it doesnt make sense to just replace a battery, who told you it was the battery? What tests did they run if any?
Second: $80 here is not even 1 hour of labor. I dont know what you meant by "thats 4 hours of labor"
2004 Saturn Ion 3 Quad Coupe
96 SSEi
Post by 96 SSEi »
hi, from all the stuff you have replaced, I would assume the car was not properly maintained, the battery can be tested before you replace it and the tensioner is easy - you may need a torx bit for it
much of that stuff could have been done by you to save lots of cash - yeah, you underestimate a auto techs rate - up here in Canada it is 100+ at GM and 80 - 100 at no name techs.
hang in there!!, you should have many miles of enjoyment once completed.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
jradke61
Year and Trim: 01 SLE
Post by jradke61 »
Yeah $80 is 1 hour at best so $80 is about right. Hell, takes 1/2 an hour to get the tools out. That's almost like a minimum charge.
*shoot*, I should get back into turning wrenches again.
Changing that tensioner is child's play tho. No need to pay anyone anything.
01 Bonneville SLE
