Black Cherry Update Page 3!
SSEiMan01
Re: Black Cherry
Post by SSEiMan01 »
A switch would be kinda neat.
Jason, I bought this knowing it would be a little more expensive parts wise. I think it's worth it, I've never had a problem paying for good quality, and I save money by doing what I can myself. :) But yeah, you know all too well about front wheel brake dust. :P
James May wrote:Hello.
BonneMe
Re: Black Cherry
Post by BonneMe »
That doesn't do any damage (other than rear tires) does it?
Make sure to keep the old shift knob, the 330i ZHP came with alcantara shift boot and steering wheel when it was launched. The next year they were already moving back to leather for the steering wheel because they didn't last well in the real world.
sethjamesrimrodt
Year and Trim: 2004 GXP
Re: Black Cherry
Post by sethjamesrimrodt »
BonneMe wrote:That doesn't do any damage (other than rear tires) does it?
Not that I am aware of. The fuse just keeps the clutch in the transfercase from engaging. There are a few threads on the Cadillac forum.
That is what I have heard about the alcantara but I looks good,
Seth
sethjamesrimrodt
Re: Black Cherry
Well I kept something off the GXP and added it to the CTS
First nice day of the year! Got a lot of things done to the car this weekend.
And I found out about this
I read some more about pulling the AWD fuse and I don't see any documentation that it will hurt anything. I am adding an OEM backup camera from a 2011 CTS next.
Seth
SSEiMan01
Re: Black Cherry
Post by SSEiMan01 »
Sweet! I really can't wait to see this car. You should get V wheels. :poke:
sethjamesrimrodt
Re: Black Cherry
If I find a set for under 2 grand I would love to have them!
Seth
SSEiMan01
Re: Black Cherry
Post by SSEiMan01 »
Keep looking, you never know!
sethjamesrimrodt
Re: Black Cherry
Green grass, clean car!
Seth
1oldman
Re: Black Cherry
Post by 1oldman »
1tinindian wrote: GM refers that engine (3.6) as their "High Feature V6", but at the dealership it is referred to as the "High Failure V6", at least those that are installed in the Traverses.
Too many mile between oil changes kill the timing chains.
Waters pump and P/S pump failures are also common.
I wish you the best of luck with yours.
The oldest son bought a CTS with 150K+ miles on it. The timing chain needed replacing. When the youngest son did replace it(them -3), it looked like the owner either never changed the oil or used the cheapest oil money could buy. It has 160k+ miles on it and is still running good. Maybe he just got "lucky". I know it's not transverse mounted, but I'd think when the engines are assembled, the engine plant wouldn't know if it was for a RWD or FWD vehicle.
Wife and I love the Dark Cherry color on the CTS, great looking car! - BC
sethjamesrimrodt
Re: Black Cherry
Thanks! Any idea how hard the timing chain was?
Seth
1oldman
Re: Black Cherry
Post by 1oldman »
sethjamesrimrodt wrote:Thanks! Any idea how hard the timing chain was?
I think CMNTMXR57 (Lane) would be the most helpful.
Here's what the youngest son did - IIRC
Be careful when you pull the sprocket off the crank as the index on the crank for the CPS to work is pressed on. If you damage it, you'll have to put in a new crank. other than that it's not too bad. Just make sure that all the sprockets, cams and crank are thoroughly marked. If you're not careful, they can move on you. My guess is that probably one out of every 30 jobs requires a new crank because the pressed on collar moved on the crank. Be sure and put something under where the crank sprocket is after you pull the timing chain cover off the keep trash and coolant out of the oil pan. If you know someone at the Cadillac dealership, you can get all the parts you need there cheaper than you can any where else, as a matter of fact, some of the parts, come only from the dealer, so it's cheaper just to buy the kit from the dealer, if you know someone that is. - BC
EDIT: Update:
This was done one year ago, so I am remembering bits and pieces.
You will need this tool to make sure the camshafts do not rotate yon you: GM Camshaft Retaining Tool Set EN-48383
http://www.shopfreedomracing.com/Camsha ... -48383.htm
Turn the crankshaft with your socket and ratchet until the #1 piston is at TDC with all valves closed (top of the power-stroke before the piston starts down). This should allow you to place the EN-48383 tool on the ends of the camshafts closest to the firewall. You will need "shims" to hold them in place (we used clean pieces of cardboard). Then mark all the sprockets (and old chains JIC). You will have to remove the crankshaft sprocket to remove any of the chains. The instructions tell you that you put the chain on the odd number bank first, then rotate the camshafts on the even number side. Don't. Only do that if you have allowed the marks and their locations to be moved. IIRC, this is an interference engine, so you have to be really certain it goes back together right.
youtube videos:
1. http://www.youtube.com/watch?v=c49ORdlIsrY
2. http://www.youtube.com/watch?v=mlRX7x7CmIA
3. http://www.youtube.com/watch?v=cwMLBv1gEbQ
sethjamesrimrodt
Re: Black Cherry (To spoil or not to spoil that is the quest
Sorry I never noticed you added more to the post, great information thanks!
I can't decided spoiler or no spoiler
Last edited by sethjamesrimrodt on Wed Jun 05, 2013 11:54 pm, edited 1 time in total.
Seth
Hotwheels
Year and Trim: 5x former 3800 Buick/Olds owner
Re: Black Cherry
Post by Hotwheels »
Looks nice - I vote for no spoiler though. It just looks out of place on a classier car with already clean crisp lines.
~Ben
2010 Chrysler 300 Touring Signature Series, Cool Vanilla - chrome 18's, MyGig touchsreen, all the toys.
2004 Chevy Avalanche LT 4x4, WBH, Arrival Blue Metallic - CAI, MBRP cat-back exhaust, lots of mods and all the options.
2004 Ford Mustang Premium convertible, Screaming Yellow - 18" staggered Bullitt wheels, 1.5" drop Eibach springs, CAI.
1973 Cadillac Fleetwood Series 60 Brougham, Antigua Blue - 23 ft, 5200 lbs, and 472 cubes of luxo-barge goodness.
1998 Chevy Corvette convertible, Light Carmine Red Metallic
sethjamesrimrodt
Re: Black Cherry
As of right now I'm agreeing with you Ben, I really liked the idea of a spoiler until I saw one in person.
Seth
Re: Black Cherry
No spoiler for me also!
sethjamesrimrodt
Re: Black Cherry Update!
I added drop springs a few months ago. I also put Camaro 20" tires on her. I am thinking about putting the factory rear springs back in??
Seth
Re: Black Cherry Update Page 3!
Post by gonzo4191 »
Looks great
1tinindian
Year and Trim: 2004 SLE Premier Edition
2005 GXP
Post by 1tinindian »
Those wheels look great!
Better tires on them too, I hope.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
I dig it. Needs some Caddy center caps.
They look huge on it.
sethjamesrimrodt
They are factory Camaro tires, Perrelli P Zeros.
I found 2 1/4" center caps on eBay.
[Image
Seth
