Need some input (temporary fix)
mylittleblackbird
Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE
Re: Need some input
Post by mylittleblackbird »
I should quit posting...
I have a Bonneville, it's white and N/A! :twisted:
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
Backhoe
Year and Trim: '98 LSS L67
Re: Need some input
Post by Backhoe »
Would a scan assist diagnosis here? I can connect you with a guy in Nanaimo with DHP if it will help.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
JMH1950
Year and Trim: no longer a Bonneville owner
Re: Need some input
Post by JMH1950 »
RJolly87 wrote:
mylittleblackbird wrote:Another thing that was mentioned in another thread, something I often forget about. Perhaps your cat is plugged.
He did advise that the cat is not a factor.
Yes, the cat is not a factor. :wink:
wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
2001 F150 a basic six cyl with 5 speed manual trans.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
JMH1950
Re: Need some input
Post by JMH1950 »
Backhoe wrote:Would a scan assist diagnosis here? I can connect you with a guy in Nanaimo with DHP if it will help.
I have the actron scanner, but would welcome a scan with a better machine.
Backhoe
Re: Need some input
Post by Backhoe »
Do you think Nanaimo is too far for your car to safely make the trip? Lyndon is a great guy, and I'm sure he'd be more than willing to help, but I'll PM him first before I volunteer him.
Backhoe
Re: Need some input
Post by Backhoe »
PM sent.
JMH1950
Re: Need some input
Post by JMH1950 »
Backhoe wrote:PM sent.
Good stuff, it might be a big help to get a scan with a better scanner. Who knows what the Actron is missing?
I e-mailed your friend, so now it's just a matter of finding a time that is convenient for each of us.
Backhoe
Re: Need some input
Post by Backhoe »
Cool, glad to help out.
Nice cruise RPM's on the Piper by the way! What's your braking distance? LOL
Re: Need some input
Post by Jrs3800 »
41 to 47 Psi ............
JMH1950
Re: Need some input
Post by JMH1950 »
Jrs3800 wrote:41 to 47 Psi ............
That's for the series 2 isn't it? The info I got says 30 to 35 psi for the series 1
Re: Need some input
Post by Jrs3800 »
No series II is 48-55 Psi
Re: Need some input
Definitely sounds like a fuel pump...
JMH1950
Re: Need some input (temporary fix)
Post by JMH1950 »
Well it turns out that if the gas tank is over 3/4 full, I have no symptoms at all. Full RPM, no hesitation, all is good.
So, I am going to be stopping for gas more often. Will see what happens down the road.
