Bad Gas Mileage
stevenmamos
Year and Trim: 2004 Pontiac Bonneville SE
Bad Gas Mileage
Post by stevenmamos »
I have noticed a drop is gas mileage recently...currently I have used half a tank and gone 99 miles. This tank reflects 100% city driving, however it doesn't do much better on the highway. Any suggestions on where I should look to improve this? My initial thought is maybe the O2 sensors, but I'm not sure. Thanks in advance.
Re: Bad Gas Mileage
Are you sure you've actually burned half a tank of gas? Maybe your fuel gauge has gone whacky. It's a common problem.
Fuel gauge has a mind of its own
Problem: The fuel gauge doesn’t work correctly. You are sick of using the trip meter to judge your distance left.
Solution: You need to replace the fuel level sensor on the fuel pump assembly. Buying this part from GM will cost over $400. Thanks to Hans, we have a simple $40-50 fix. The fix involves buying a part from a GM dealer that is made for a recall on Tahoe’s. What happens that makes the sensors not read correctly, is the little fingers on the sensor wear out, causing false readings.
Bad sensor: http://i33.photobucket.com/albums/d61/b ... G_7569.jpg
Good sensor: http://i33.photobucket.com/albums/d61/b ... G_7572.jpg
Luckily GM made it easy to get the fuel pump out by making an access panel in the trunk. You simply remove the pump from the fuel tank, and swap the sensor arms, and reinstall. For a more detailed explaination with a video tutorial, see here: viewtopic.php?f=9&t=3463
Pics here: viewtopic.php?f=18&t=456
Part number needed: 15824379 ($43.30 as of 5/8/11)
Estimated Cost: $40-50 for the part from GM, $20-30 on ebay
However, if you rule this out, what is the maintenance like on the car?
stevenmamos
Re: Bad Gas Mileage
I've already had the whole gauge cluster replaced, and I've also calculated my gas mileage during each full up by the amount of gas I put in. It is a meticulously maintained vehicle and has new plugs and wires about 1,000 miles ago. I have also run fuel injector cleaner through the tank recently.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
What plugs and wires did you use?
Re: Bad Gas Mileage
Like nos4blood said, did you fill up and get appx. 9 gallons? Or is the cluster showing 1/2? The sender in the tank is a common cause of failure, but we need to make sure we know what's going on.
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease or Amsoil Grease recommended)
    PCV Valve Every 30k
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX) http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
    Spark Plugs Every 30-50k (NGK TR55, AC Delco 41-101 or Autolite 605) (Never Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Valvoline SYNPower, Pennzoil Platinum, or Amsoil )(Mobil1, Purolator PureONE, Amsoil EaO, K&N or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(API SM/SN rating) (WIX (Napa), Delco or Purolator filter)
    Tires: Check Inflation Pressure & Visually Inspect Monthly Rotate Every 6-8,000 Miles
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) viewtopic.php?f=45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Mixes-With-Any Coolant Only) (Never Dexcool)
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only) viewtopic.php?f=45&t=13626
    Brake Fluid Flush 3yr/50k
    Power Steering Fluid Replacement/Flush Every 100k or 5 years
    *Special Considerations*
    All Series II/III 3800's RPO's: L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
7/29/2012 by 00Beast
stevenmamos
Re: Bad Gas Mileage
They are Duralast wires and AutoLite Platinum plugs. Already fixed the gauge issue and calculate my mileage with the distance I travel and the amount of gas I put in.
01bonneSC
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
Have you changed your LIM gaskets and upgraded to the new style UIM?
stevenmamos
Re: Bad Gas Mileage
I'm not sure the LIM has been replaced but I know for sure I have the updated UIM installed.
01bonneSC
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
You are an 04, not sure if they gave you the updated LIM gaskets or not from the factory.
Check between the cylinder head and the LIM. If the gaskets is black its the old version and should be changed. If its silver/aluminum looking, it is the new style and you should be ok.
Notice any coolant loss?
Re: Bad Gas Mileage
No L36 got any upgraded gaskets in any year.
Not sure on the N/A, but on S/C, platinum plugs are bad. Nothing Duralast has proven to be any good that I've seen, however...
LeSabre in Buffalo
Year and Trim: 2012 Eco
Re: Bad Gas Mileage
Post by LeSabre in Buffalo »
Were the plugs gapped correctly, or did they get installed without gapping? Those plugs should be gapped to 0.060", IIRC. If they're gapped under that, then gas mileage will go down.
To gap them, get a wire gapping tool, not one of those "coin" gappers. Bend the electrode, and don't force the wire into the gap.
1oldman
Re: Bad Gas Mileage
Post by 1oldman »
When the fuel mileage drops drastically on the ole green monster, I replace the o2 sensor. That has fixed the problem almost every time. - BC
01bonneSC
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
How many miles on the car?
stevenmamos
Re: Bad Gas Mileage
The plugs were gapped correctly. There are about 99,000 miles on the car.
01bonneSC
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
You could try taking the O2 sensor out and cleaning the soot off with some carb cleaner. See if that helps.
At that milage it wouldn't be throwing money away to put a new one in. Go with ACDelco as the brand.
Arrowhead
2005 GXP
Re: Bad Gas Mileage
Post by Arrowhead »
Have you checked/changed air filter lately? It's a simple thing that can/will waste a lot of gas if it's really dirty and restricts flow. :wink:
stevenmamos
Re: Bad Gas Mileage
I might try cleaning the sensors. Heard that air filter doesn't affect gas mileage, just performance...(http://www.fueleconomy.gov/feg/maintain.shtml). Also found out that there have been people in my neighborhood siphoning gas from vehicles at night...so just bought a locking gas cap hoping that this is what is happening. We shall see.
Re: Bad Gas Mileage
No, a plugged air filter will kill performance AND mileage. Co-worker just went through this on his F150, lol. Filter was PACKED with crap.
Do you really believe what the Government says about your car?!
01bonneSC
89 SkiDoo
Re: Bad Gas Mileage
Post by 01bonneSC »
Performance and MPG are directly related.
LeSabre in Buffalo
Re: Bad Gas Mileage
If you can't remember the last time the air filter was changed, it's a good idea to change it. Once every few years and 30-50k miles is generally enough for most cars. Filters get more efficient as they age and fill up, up to a point. After that point, they're too filled with junk to pass much air. So, just like the 3 little pigs, one doesn't want to change the air filter too often or too soon.
