Dorman Coolant Elbow Recall
vogie01
Re: Dorman Coolant Elbow Recall
Post by vogie01 »
I called Dorman on Monday morning, but I forgot to update this though. I ended up speaking with an engineer, and he said they have not recalled anything, but he has heard of widespread leaks among the "3800 sector" as he put it. He said there was a new design out, and that spot check inspections at stores is being done. He said no recall as of now, but he swore up and down multiple times that if I had a set that failed or knew of anyone who did that Dorman guarantees the retailer will replace with new set with a receipt because they now have a lifetime warranty.
Warranty page: http://www.dormanproducts.com/Pages/Hom ... ranty.aspx
Hm. Interesting. I got mine from Rock Auto and sealed them with RTV, so my fingers are crossed for no leaks.
Jfridge92
Post by Jfridge92 »
Add another to the list with one leaking...less than 6 months after the upper and lower gaskets were done, AND I used RTV on them.
Joseph
1999 Infiniti G20T - Sold
SSEiMan01
Post by SSEiMan01 »
00Beast wrote:Hm. Interesting. I got mine from Rock Auto and sealed them with RTV, so my fingers are crossed for no leaks.
The first three sets (Dorman) on my car were sealed with RTV too. This set (GM) seems to be holding well, along with a new tensioner, that's not corroded.
James May wrote:Hello.
rkpatt
Year and Trim: 1999 Olds 88 LS
Post by rkpatt »
I need to change a leaking coolant elbow on my car and want to make sure that I get the new Dorman product .
Does anyone know how to distinguish the new improved version vs the old version of Dorman coolant elbows (ie difference in packaging or part # etc).
Also - red RTV on LIM o-ring for "insurance" Y/N ?
-Thanks
"This might require a call to Dorman's corporate offices. My mechanic friend that informed me of this said that O'reilly's Auto Parts did not have any in stock the other day because Dormant pulled them all from the shelves due to a leaking issues. He said they do have a new updated version of the elbows. He said he has had three cars come back in the last three weeks due to leaking coolant elbows that he had just replaced."
rkpatt
Post by rkpatt »
Same problem here. I wonder if one can identify from the package (part#, color etc) as whether the stock at the auto parts store (usually O'Reilly for me) is the new design ?
vogie01 wrote:I called Dorman on Monday morning, but I forgot to update this though. I ended up speaking with an engineer, and he said they have not recalled anything, but he has heard of widespread leaks among the "3800 sector" as he put it. He said there was a new design out, and that spot check inspections at stores is being done. He said no recall as of now, but he swore up and down multiple times that if I had a set that failed or knew of anyone who did that Dorman guarantees the retailer will replace with new set with a receipt because they now have a lifetime warranty.
reb
Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner
Post by reb »
Just replaced a Dorman elbow that was only installed since thais past June (7 months old) I used Permatex 27B on that install and it still leaked. This time I permatexed the entire external "gap" around the tensioner side andgot a nice even ooze of a seal on the intake side. The leaking elbow I replaced was not warped in anyway but the O Rings looked flat and aged (prematurely worn after only 7 months- only a few thousand miles)
rkpatt
Post by rkpatt »
I contacted Dorman tech support about the bad coolant elbows. They told me that there was a problem but were not specific about it (didn't mention o-rings and I forgot to ask). They told me that the "improved" version has production code number of 11300 or higher stamped on the elbow. Who knows... :roll:
Troyport
Year and Trim: 1993 Bonneville SE, restoration finished
Post by Troyport »
LOL... leaked on my 1999 eighty-eight. Oh well, car is gone now. Need to update my signature I guess.
1993 SE with SLE appearance package. Factory stock except for steering wheel buttons, AM/FM/CD from a '93SSEi and chrome wheels.
1999 Olds Eighty-Eight LS Anniversary Edition, my daily driver.
2004 Chrysler Minivan, wife's daily driver.
irish91983
1992 Bonneville SSEi (Sold)
Post by irish91983 »
Same problem here. I have taking them out and reinstalled them 3 times now and still are leaking. Think I'm just going to get a set of GM ones and hope for the best.
2001 SSEi Bumbles
Angel Eyes ~ Cleared Corners ~ Tinted Tails ~ Intense FWI ~ 20% Tint ~ 180 Drilled T-Stat ~ GXP Brake & Suspension Upgrade ~ Alternator Rewire ~ Intense Shift Kit ~ Headers ~ Tr 6's
Fan over ride~NGK Tr 55's~180 Drilled t-stat~Clear Corners~Angel Eyes~Tinted Tails~Magnaflow Cat
yonkerse
Post by yonkerse »
Same issue here. I have tried correcting the leak 3 times, each with Dorman elbows. Mine are currently still leaking slightly....only when the car sits for a long period of time. I'm anxious to try the new Dorman design once were able to locate them!
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
rkpatt
Post by rkpatt »
I just looked at a Dorman coolant elbows in a packed that a recently arrived at my neearby chain autoparts store. The elbow with the same diameter ends had 11300 stamped on it .
The elbow on my car (1998 Oldsmobile 3.8) is the elbow in the package that has 2 different diameter ends . The larger end of the Dorman elbow has a purple o-ring . This compared equally with the leaking elbow I removed . The o-ring is not as thick as the o-ring from the original GM elbow .
I am not convinced that there has been anything done (ie facilitating at tighter fit in the LIM bore ) for the elbow on my car . I am back to getting an elbow from GM or getting a thicker o-ring from NAPA (most are BunaN) which hopefully is heat and antifreeze resistant.
yonkerse
Post by yonkerse »
rkpatt wrote:I just looked at a Dorman coolant elbows in a packed that a recently arrived at my neearby chain autoparts store. The elbow with the same diameter ends had 11300 stamped on it .
Could you post up a picture of the new ones?? please..
Eric
A few mods..
SSEiMan01
Post by SSEiMan01 »
Yes, a pic of the package and part number please. For future reference for the members here. :)
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
I'm not convinced that the source of the leak is the seals.
My elbows (I am now on set #4) are warping, losing the 90 degree bend and being pushed out by the pressure in the coolant system.
I have a Failsafe thermostat, and it reaches over 230 before opening (initally) then maintains about 200. So unless they switched plastics in the new elbows I don't think they have solved the issue. Note that I didn't have a problem when I still had the stuck-slightly-open original thermostat that took 15 minutes to get up to temp. Doorman is using an incorrect plastic for the application. I think you guys aren't getting as hot initially as I am, so the plastic is losing it's shape (and therefore it's ability to seal) on the ends where they interface with the manifold first (maybe the hottest point normally, whereas my coolant temp reaches 230 daily).
I think the OEM elbows are probably fine, I replaced them as P.M. when I did the rebuild, but they weren't leaking yet then. I wish I had taken the seals off the doorman and put them on the delco elbows now.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
SSEiMan01
Post by SSEiMan01 »
My Dormans, well, one set warped, one had bad o-rings, and third warped and my tensioner was corroded. :roll:
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
I had over 30 sets fail on me this past fall. I've got all the receipts but didn't think to save them when I bad elbows.
What I found was failing were the o-rings.
I would use Permatex ultra black rtv as lube and to aid in sealing, but in a matter of 2-3 weeks the o-rings would flatten out/shrink.
Since the GM elbows were ~$20/set I started buying the Dorman elbows, but I would buy GM o-rings and put them on the Dorman elbows.
Cost comes to ~$10/set vs $20 from the dealer.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
yonkerse
Post by yonkerse »
olblueeyesbonne wrote:I had over 30 sets fail on me this past fall. I've got all the receipts but didn't think to save them when I bad elbows.
Interesting idea. Do you recall the GM part number for the O-rings you used??
Eric
A few mods..
WilliamE
Year and Trim: 96' Buick Park Ave w 3800 II NA-L36
Post by WilliamE »
Hello Pontiac Bonneville Club'ers, I do not have a Bonne, but may some day, I do however have a 3800 II engine that has had the same coolant elbow problem, I replaced mine when I did a UIM/LIM job, and had them leak in under 100 miles.
I knew once I first seen the Dorman O Rings that they looked a tad smaller, so after I noticed my leak I took the Fel-Pro O Rings that came with my LIM Kit, put them on with no RTV and had no leaks so far, and it has been a few hundred miles.
I know some say they melt, I personally have not experienced this, my old elbow did fall apart at both ends once I removed it though, it had been on there 133k leak free from the day the car was made.
Olblueeyes is dead on the money in my opinion, the elbows are fine it is the o rings, I seen mine flatten out too much in under 200 miles, so imaging how may just keep driving, topping their cars off on occasion, and not knowing they have a little coolant leak...
Here is a pic of mine side by side, in the second pic I had them at an angle so the left one which is the Fel-PRO one looked smaller, when it is actually just a tad bigger..
Uploaded with ImageShack.us
rkpatt
Post by rkpatt »
I will be changing the coolant elbows very soon and wondered if anyone has yet used the "improved" Dorman coolant elbows . Are they better than the old ones ?
BTE- I haven't been back to the parts store however I am pretty sure that the part # and packaging was the same. I asked the parts guy to open the package to let me examine the two elbow .
The elbow on my car (1998 Oldsmobile 3.8) is the elbow in the package that has 2 different diameter ends . The larger end of the Dorman elbow that fits into the LIM has a purple o-ring . This compared equally with the leaking elbow I removed . The o-ring is not as thick as the o-ring from the original GM elbow .
