Mounting clips for aftermarket HU
entourage
Post by entourage »
Ok, I've searched high and low and can't seem to find an answer.
Trying to install a new HU in my '02 SE and wondered what other people were using instead of the metal brackets that were mounted on the factory radio?
I seem to be missing the threaded retainer clips to put screws in to hold the new HU mounting kit to the dash:
You can see the slots above and below where the original metal clips attached, but I don't see any way to attach those to my new mount. I would think if I could get those clips, I could just screw the new kit to the dash:
Any ideas??
Thanks in advance!!!
swampthing
Re: Mounting clips for aftermarket HU
Post by swampthing »
I'm not sure how everybody else did it. I just zip tied it in there honestly
Current fleet:
entourage
Post by entourage »
I was thinking from past GM installs that they each had something like this:
It's called a 'U' Nut...
There is a special snap in retainer nut, not sure why yours are missing... but I'd be glad to sell you some ;)
PM me.
entourage
Post by entourage »
That's exactly it! Thanks! PM coming your way.
Djkthegame
1987 Bonneville LE
Post by Djkthegame »
you can also try the nylon nuts that are used for rear license plate holder, the white square ones that u can plug into the square holes and the put a screw into. you can buy those at autozone and they come in two diferent sizes. i had to do this before and it does work its just been a while so i forgot which sized one it was.
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
What I sent him is exactly what he needs. If anyone else needs them, just PM me.
entourage
Post by entourage »
Yeah, sorry I never posted back, but yep...worked perfectly! Thanks!
