Auto Start Tachometer wire North Start
zigger21
- Year and Trim: 1997 Bonneville SSE
2005 Bonneville GPX
Hello Guys. I am having a very difficult finding the tachometer wire for Northstar engine for wiring up a security auto start. I really need some help because this is mainly my only hang up. . I begging for help here. Take Care.
stevew9983
- Year and Trim: 2000 Bonneville SSEI
Re: Auto Start Tachometer wire North Start
www.commandocaralarms.com
try that website and see if you can find the wiring diagram you need, they offer free wiring diagrams for remote start units
I am not familiar with the northstar and GXP, but I do have the tachometer circuit description from the 2k FSM and I am willing to bet the others are done very similar.
What is the need for the tach input?
Basically there is no single wire. It is calculated internally in the instrument cluster based upon the signals from the PCM. The PCM gets it's information from the CPS and cam sensor.The tachometer displays engine RPM (speed) anytime the power mode is RUN. The engine RPM is calculated by a discrete signal sent to the IPC from the PCM. The engine speed signal is active low, with a pull-up resistor located in the IPC and connected to switched battery voltage. The signal is a square wave with a 25 to 75 percent duty cycle. Each engine revolution is represented by 2 input pulses. Engine speed is calculated using the time difference between the 2 consecutive pulses. Accuracy of the final calculations are +/- 25 RPM.
