Help please !!!Compressor
shawnyoung
- Year and Trim: 2000 ssei
If compressor is not letting air out is there any way to fix that or do you have to replace compressor. My rear shocks are staying pumped up. Any suggestions appreciated.
- Archon
Re: Help please !!!Compressor
The most common cause for that problem is the ride height sensor not working properly. I'd try replacing that first.
golfyeti
- Posts like an LG3
- Year and Trim: 2000 SSEi
Could there be a fuse dedicated to the air-pressure-release mechanism?
Mark
The Familyman's Trans-Am
01bonneSC
Fuse under rear seat. Look in owners manual to see what number. Thats what I take out after shocks are aired up at the dragstrip, so they dont bleed down.
I doubt it. It's all part of the compressor.
01bonneSC
Doubt what? The fuse?00Beast wrote:I doubt it. It's all part of the compressor.
I doubt there is a separate fuse just for the air release mechanism on the compressor. I guess it is possible, but unlikely.
01bonneSC
There is. Never done the ELC trick at the stip?
The ELC trick I did involved disconnecting the arm, and fooling it into not releasing the air by letting it "spring" all the way up, making it think the suspension was bottomed out. Never pulled a fuse.
