Front cig lighter quit working
mydadscar
Year and Trim: 1993 Pontiac Bonneville SSE 153K miles
Post by mydadscar »
the front power source/cigarette lighter on my 93 SSE quit working. Back one still works fine, but hard to operate my iPOD from there while driving. Any ideas what to check or how to fix? My first thought was to take off the trim around the radio, pop out the radio and then see if I can get a look at the back end of the lighter bracket to see if a wire is broken. Is it possible the two lighters are on separate fuses-one works and the other does not?
TampaSSeI95
Year and Trim: 1995 SSeI Juiccccedd
Re: Front cig lighter quit working
Post by TampaSSeI95 »
check the fuse i have 2 different ones on mine i believe
yup my 95 has 2 different ones for the cig lighters one says c/ltr and the other says rr dr c/ltr
Only Race Cars Have Nitroussssssssss
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Post by petraman »
Check ALL the fuses (the one in my Impala, believe it or not, is labeled separately from the cigarette lighter :roll), and make sure to keep change away from the outlet :wink:
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
mydadscar
Post by mydadscar »
Thanks for your replies, but both the fuse under the dash left of the steering column (power accsy), and the 50amp big fuse in the box on the firewall under the hood are good. Any other suggestions short of taking the dash apart?
You are trying it with the ignition on, correct? I know one of them is only activated by the ignition, while the other is always live.
mydadscar
Post by mydadscar »
yes, I have tried with key on and key off. Back one works all the time. Front (dash) does not work at all. The front reciever socket started to work its way loose til the sleeve would rotate in the socket. I fixed that with Gorilla glue but now I wish I would not have done that since I may have to get back in there and push the socket out of the dash if a wire has come loose. What do you think?
willwren
Post by willwren »
At least through 1995, both lighters work without the key.
I have a new socket, and new wiring I can sell you.
mydadscar
Post by mydadscar »
I have to get into it first to see if that is what I need.
