Will a 92 rear air compressor work on a 94 bonneville?
Both cars are SSEi.
Both pumps are on the L/S fender.
I am concerned about the mounting and wiring.
Please LMK.
Thanks
Rich
92 air pump on 94?
- DaBlackPearl
- GXP Member
- Year and Trim: 1994 SSEi Bonneville
Series 1 Supercharged - Location: St.Louis Area
92 air pump on 94?
Thanks, Rich
The Black Pearl-94 SSEi stock 150,000miles
MODS...Magnaflow Cat, Magnaflow F-body Muffler, 180*F T-stat, 2.5"pulley, Yella Terra 1.8" roller rockers, custom CAI box, 93'SSEi fuel pressure regulator(3.0BAR), Walbro HP fuel pump, reman Jasper trans, new front suspension
- J Wikoff
- Year and Trim: 1992 SSE
Re: 92 air pump on 94?
92-95 air pumps, level sensors, and brackets have the same part numbers.
- spoiledred94
- Posts like a Northstar
Can you replace the air compressor on a 94 with an air tank adjusting for ride manually with tank in the trunk? My 94 SE did not have ELC and I bought shocks for it that were for the adjustable ride. I want to attach lines from the struts leading to the tank and stiffen it up hard for performance trips manually.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
You could add a kit with some lines to schrader valves to fill from an air compressor, etc.
- J Wikoff
I don't see why not. You could set it up like any airbag suspension.
- spoiledred94
When I had my alignment done the mechanic said he could get schrader valves, t's and line from his distributor. I after reading the thread I questioned whether I need the compressor or not. The refit is only like $25 + the tank if you have the struts,
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
