Window regulator?
bonnevillain
- Year and Trim: 2002 SLE
Window regulator?
My drivers side rear window stopped working.. it was intermittent for a while, and now it's stopped completely. I don't hear anything happening when i try to move it, would that still be the regulator? or should I take a look at the switch/wiring/door module.
zuluhead
- SSEi Member
- Year and Trim: 2000 SSEi
Re: Window regulator?
have you pulled the door panel off yet? I can't hear anything from my regulator with the panel on.
If you're still not hearing anything with the door panel off I'd stick a multimeter on the connection to make sure power is getting to it. I'm sure someone can provide a pin-out and expected values.
2000 Bonneville - SSEI
If you can't hear anything, its probably not the regulator. Is the window still up? The window should fall down if the regulator is bad.
bonnevillain
yeah, the window is still up. That's kind of what I was thinking.
Time to re-install that Techline ESI DVD
EWC88
- Year and Trim: 01 Se
Not to hijack this thread but my passenger side rear window regulator I believe went but just want to be positive. I was able to lower my window the other day but when I went to put it up it won't move. I am able to pull the window up a certain height then when it gets about 3" from the stop there's pressure that doesn't let me pull it up anymore. When I hit the button I do hear a noise.
Sorry didn't want to hijack but figured were having almost same problem so why start another thread.
R.I.P 2001 Se :(
Yup, thats a regulator.
zamjohn
- Year and Trim: 2004 Bonneville SE
I just had a similar problem on my 01 Silverado and I don't know for certain that GM uses the same system on their cars that they do on the trucks but I have reason to believe they would. Yes it would then be a regulator problem. However I didn't buy a new regulator. I just replaced a frayed cable and the housing that it ran in. You have to use some ingenuity to fasten the cable in the drive pulley but it cost me $5.50 as opposed to $100.00 plus for the regulator from a jobber(GM is more). GM doesn't sell these cables, (either the brake cable or the shifter cable works), but your nearest bicycle shop does and that is all they are using. If you take this route just make sure you get the cable exactly the same length as the original once it is installed. The cable is galvanized so it doesn't work to solder it. Best of luck! zamjohn
The cable isn't what fails in the Bonneville regulators. The plastic piece that holds the 2 cable ends together gives out.
EWC88
With my problem do you think I could just do the mod of fixing of the regulator that was writing up in the techinfo area or am I looking at buying all new?
R.I.P 2001 Se :(
No way to be sure until its out of the car and inspected.
EWC88
Do you have the write up on how to get the motor and regulator out of the door? For temporary I was able to pull up on the window while pushing the button up for it to be able to get closed and I then put things inside the door to keep the window up.
R.I.P 2001 Se :(
its pretty simple. 2 bolts hold the window to the regulator, and 3 bolts hold the regulator to the door.
EWC88
Ok I'll tackle that tomarrow after class. I guess use fishing line to get glue off the window from holding it on the regualtor?
Found this site that has new regulators with motors for the cheapest I seen:
http://www.am-autoparts.com/AM/Window-M ... ille/2001/
R.I.P 2001 Se :(
There is no glue. 2 bolts I said.
- spidey3479
- Posts like an L27
- Year and Trim: 2001 SSEI, 2004 SLE
If you are going to replace the whole mechanism it is a fairly easy repair. There is enough room to get everything in and out and the door panel comes of easily. You'll just need enough time to completely do it. Took about an hour and a half last time I messed with my 88SSE and it was a little tougher repair.
1988 SSE-Gone but not forgotten.
2001 SSEI-304,572 miles, 3.5 Pulley, Intense PCM, Intense FWI Spectre filter, 160 tstat, ngk iridiums, belden wires, Silverstars-high and low beam, rebuilt tranny, shift kit, cooler, Dex VI fluid, replace the rear compressor and lines and level sensor, Monroe air shocks in back, FE5 struts and Moog strut mounts, Moog stabilizer bars, AC\Delco control arms.
2004 SLE-Stock, 195,000 miles,oldest son's baby now
2000 Ford Ranger-Stock, 352,000 hard, pizza delivery miles, new control arms (upper and lower), new(used) tranny
