Wax on Clearcoat
- dissmn8
- Year and Trim: 2001 Bronzemist Metallic SLE
Wax on Clearcoat
I was recently told by a body repair specialist that utilizing wax on a modern clear coat finish is a big no no. He claimed it will dry out the clear coat and cause it to crack long before its time.
Anyone??
114K and going
114K and going
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Re: Wax on Clearcoat
I bet that guy isn't very busy is he? With advice like that, I would run away for sure. Wax will not dry out a clear coat and cause it to crack. A wax / sealant is actually a good thing for any car, including modern cars.
The only time you want to avoid a wax / sealant is with fresh paint.
- dissmn8
AHA!! Maybe he was confusing me.
I thought he was crazy.
114K and going
114K and going
- crash93ssei
- Retired Moderator
Yeah, he was way off there.
Wax is great for our cars, not to mention it looks very good
- Red Rocket
- Year and Trim: 2000 Pontiac Bonneville SSEi
Exactly. If only I had pictures to show you of what happens to the paint on a car when you don't wax it. I'll just say that it's not pretty at all.crash93ssei wrote:Yeah, he was way off there.
Audio: 12" Alpine Type R in 2.3 cu. ft. box tuned to 31 hz, Audiobahn A8000T, Rockford Fosgate 3sixty.1, Kicker wiring
Mods: Cross drilled and slotted rotors, hopefully more to come soon
A wax or a sealer would be a good thing as it supplies the paint with nutrients and oils
An abrasive polish will wear out the clear coat... Big difference here
- Aviator327
- Posts like a Northstar
- Year and Trim: 2002 Bonneville SLE
Meguiar's Gold Class rocks.dissmn8 wrote:AHA!! Maybe he was confusing me.I thought he was crazy.
THE AVIATOR'S BONNE
2002 SLE, Purchased 10-18-07. 35,341 miles
Silverstars, 9005ST,9006ST
- olblueeyesbonne
- Retired Moderator
- Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT - Location: Sauk Centre, MN
Aviator327 wrote: Meguiar's Gold Class rocks.
For an entry level polish, but when you want the good stuff stick with Meguiars and get the blue round tin with the #16 Professional Glaze Wax.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
95SLE
- Year and Trim: 2004SLE
dissmn8
Your color can go either way wax or sealant and look really sharp. I have seen one 2K+ Bonny in my neck of the woods that looked super.
What is your total budget you are willing to spend?
I am sure Ryan and I can make a few suggestions within your budget.
For over the counter product it is hard to go wrong with Mothers 3 step system and a lot of elbow grease. Your investment for the 3 products plus Mothers car wash and the proper applicator pads and cloths to take off the wax would be close to $50. I used the Mothers 3 step system for almost 15 years and was satisfied with the results.
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
- dissmn8
95SLE - $50 just for a wax system.
I am not sure how you would justify that.
Paint on this 01 is in really good shape. I just want to keep it that way. As far as budget........I have a buffer and would be looking for a good wax that can be applied and buffed off again. Try to keep me under $20.
114K and going
114K and going
- Red Rocket
First off, $50 is not much at all to protect the paint of your car. Consider how much it would cost to get it repainted properly. It would probably cost at least a few thousand dollars. Spend a little now and save a lot later.dissmn8 wrote:95SLE - $50 just for a wax system.I am not sure how you would justify that.
No offense but if you can't afford to spend $50 to protect the paint on your car, you really shouldn't have a car. Cars are extremely expensive to maintain and keep running but I'm sure you know that.
I wish I had spent the money and time to clean and wax my old 94 but I didn't and the paint looked horrible after a few years. I've learned my lesson that it just isn't worth it to be cheap because you pay in the end.
I'm sure you can find a way to come up with $50.
95SLE
For under $20 you are really into the grade "C" class waxes. The top of the line is Mothers the wax only. In the middle is Eagle One pure Carnauba and at the bottom is Rally cream wax.dissmn8 wrote:95SLE - $50 just for a wax system.I am not sure how you would justify that.
D class is a wax like Megs Quick wax.
For a beautiful car like yours I would at least not stop at Mickey D's or Starbucks for two weeks and get a tub o P21S. You will be glad you did.
The guys and gals on this board are all about helping other members and saving you money. It is really hard to skimp on a wax and get a popping shine.
I also believe that dong something is much better than nothing at all. Who knows we may see each other at a meet and I can show you the difference between a $15 wax and a $35 wax. The extra $20 is not bad for the difference in the shine and the lasting power.
COTM April 2007
- Aviator327
Thanks, will have to check it out.olblueeyesbonne wrote:Aviator327 wrote: Meguiar's Gold Class rocks.
THE AVIATOR'S BONNE
What do you think about the Eagle One Nanowax? It looks good for me on one application, and then like crap on another.
- BonneMe
Megs professional products are great too. I've been using some of those, and some other smaller brand products.
P21s/S100 is great stuff, It's my wax of choice. For sealants i've used Megs #20/21 with great success as well. If anything it's even easier than the P21s/S100 to put on, and lasts much much longer. It doesn't quite pull colors through like the P21s though.
- dissmn8
OK. Got alot of good advice. No concensus. Anyone know how to do a poll??
114K and going
114K and going
- *B2*
- Posts like an L36
- Year and Trim: 2000 SLE - Black
You can get a great wax for under $20. Collinite 476S. Check for it on ebay, should be about $15 shipped. Almost anything that is OTC isn't going to be very good.
Black 2000 SLE
- Aviator327
It must be discontinued. Did a search on meguiars site but couldn't find it.olblueeyesbonne wrote:Aviator327 wrote: Meguiar's Gold Class rocks.
THE AVIATOR'S BONNE
M1611 Paste Wax was discontinued in the U.S. due to VOC regulations. Chances are you can still find it around.Aviator327 wrote:It must be discontinued. Did a search on meguiars site but couldn't find it.olblueeyesbonne wrote:Aviator327 wrote: Meguiar's Gold Class rocks.
2001 Grand Prix GTP Special Edition
1997 Bonneville SLE- Totalled
August 2004-March 2007
Yes, #16 is around, but not easy to find. You usually will end up paying $30 for a tin. I'm with B2 and would suggest Collinite paste 476 or the liquid 845. They are great for someone that doesn't have a lot of time or money to wax. You can find either for $15-20 shipped. The 845 is a little easier to use, but the 476 will last a little longer. I have the 845 and it will make it 4-5 months easy.
