"Designed for vehicles without OnStar® or Premium BOSE® sound systems."
Are you wiring the module directly to your speakers? If not, this is likely the problem. I'd have to have a close-up pic of the 32 pin DNL connector to see what wiring is present, but I'm willing to bet that it isn't wired to support the amp.
RainSense Wipers, Backup Camera, '00 Style Door Panel Courtesy Lights, Heated Washer Solvent, 2X Remote Trunk Release, Turn Signal Mirrors, Center Console Courtesy Lamp, Rear Outboard Heated Seats, PVD Chrome 18" Factory Rims, Upgraded
Yeah, the wording is kinda tricky. Bose "Premium", which is what the installation guide states, usually implies an external amplifier. This however can also refer to a Class 2 amp sometimes which wouldn't apply here since the Monsoon amp is a non-Class 2 amp. A couple of questions...
What do you have the three blue wires that are tied together connected to?
Have you verified that your new head unit works in an environement outside the Bonneville?
It looks like the wiring to support the amp should be there.
the three wires were connected together from PAC and never said anything on them.. since its blue and white i assumed it was the amp remote...
so i have it connected to the amp signal wire on the deck
i tested my head unit at a small speaker at work and it worked fine... but never tested it on amps to see if it works..
yet i scanned the remote signal wire coming out of the deck and it gave me 12 v.. which means it works..
i also tried connecting the remote wire in the harness to a 12v source didnt work
im really giving up on this thing already....
Cardomain link Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
When you say that you connected the remote wire in the harness to +12V, I assume you are referring to the vehicle harness? Can you be specific about which terminal this was (include the wire colour as well).
I'll post some info later on. The Bose amp is definitely not wired the same as the Monsoon. They are not even close to being pin for pin compatible (at the amp end).
Based on how it's wired, there's no reason that you shouldn't be able to use the wiring already in place. It's really about how it's wired up at the HU end. Part of the problem may be that the Monsoon amp senses a radio on signal as well as uses the 14V ref line. This is what I need to dig into a little more. The Bose amp doesn't (IIRC). With vehicles that have the Bose amp, one of the inputs on the back of the HU is grounded and this is how the radio knows it's there. It then uses a different signal to turn the amp on. Monsoon amps are a little different.
Two of these have to do with the amp. One is related to the 14V Ref signal, one is Radio On Signal and the last is the antenna module enable. Our cars have an antenna module that is part of the Diversity Antenna system and needs to be enabled when the radio portion of the HU is active.
How about I check this out a little more first He has a different amp. The computer all my technical documentation is on a different computer. As soon as I can get to it, I'll look over the diagrams. Believe me, I understand your frustration and drive to get this done.
