Rear Engine Mount
- JBMark33
- Posts like an L36
- Year and Trim: 2000 SE
Rear Engine Mount
How can I determine that its' bad?
Is it possible to see from the engine bay or do I need to get underneath the car?
Current: '12 Audi S4 Quattro Prestige 6MT
Previous: '06 Audi S4 Quattro 6MT (for sale!)
'06 Chevy Cobalt SS, Stage II: 2.0L Supercharged, 16psi boost, G85 Package; Recaro Racing Seats, Limited Slip Differential, 5 Speed Manual
'00 Pontiac Bonneville SE ( 4 years, 197,000 miles)
'99 Dodge Intrepid ES (1 year, 2 engines)
'95 Chevy Lumina (2 years, 164,000 miles)
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: Rear Engine Mount
You might be able to squeeze in and catch a glimpse of it from under the hood, but you'll want to go under the car to inspect it. Checking it shouldn't be to hard. Get the car high enough so that you can get under it and have someone put it in drive, reverse and neutral a few times. If you see the mount moving too much its going bad.
Have you changed any of the other mounts before? The front trans mount is really easy to get to and work with, so be sure it's not that one first. For the record the mount in the rear is the Rear Trans mount, if you go looking for a new one that's what you'll want to look for. The engine mounts are on either side, trans mounts are front and rear.
Changing the rear trans mount is a PITA, at least it was for me. You will need to either lift the engine up or lower the sub frame a couple inches to be able to wiggle that sucker out of there.
- JBMark33
- Posts like an L36
I have tried a solid mount and the OEM mount in the front, and both times I was still having a lot of engine movement. IMO, when I installed the solid mount, that put the rear tranny mount on it's last leg.
rrounds
- Posts like an L36
- Year and Trim: 2000 SSEi
How many miles do you have on the car ?
I have 186k with over 150k with the solid mount
and my other mounts are still good(even with Cindy driving the car
ROD
ROD
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
- Archon
With your foot firmly on the brake, put the car in reverse and give it a bit of gas. If the engine rocks forward, then the rear mount could be bad.
RookieSSei
- SSE Member
- Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
yea I think my rear is going the engine *dang* near jumps at me like a 3d movie lol..
Have you replaced the front mount yet? That'd be what I checked before the rear mount.
- JBMark33
- Posts like an L36
Yeah, i had previously tried a solid mount setup, but I had a ton of vibrations. I went back to the stock mount after a controversial affair over my mechanic suggesting the OEM engine mount for inspection last month.
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
how much did u pay for the oem front mount ?
- JBMark33
- Posts like an L36
$61.99 + Tax.
SLEighride03
- Year and Trim: 2012 Nissan Sentra SR Special Edition
- JBMark33
- Posts like an L36
I made it. Bought a 9" X 0.5" Threaded Rod, put it through three hockey pucks and used lock washers and nuts to keep it together. I put thick rubber washers on the ends, under the frame and on top of the transmission bolt on location. I probably should have used some endlink bushings instead. I had too much vibrations for my liking.
My comment was mostly aimed at RookieSSEi. I knew you'd tried both a new marshmallow and solid mount.
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
I replaced the front one with a napa mount last aug. Now it's bad so I was just going to replace both with oem mounts anyone got the part number for a front an rear trans mount 02 bonnie . P.s will this stop my movement? Or should I overkill an replace all the mounts
- JBMark33
- Posts like an L36
If you do the rear mount, let me know how it goes.. I heard it's a little challenging. Not much room to work, so the cradle has to be lowered or the engine raised 2"-3".RookieSSei wrote:I replaced the front one with a napa mount last aug. Now it's bad so I was just going to replace both with oem mounts anyone got the part number for a front an rear trans mount 02 bonnie . P.s will this stop my movement? Or should I overkill an replace all the mounts
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
okay i orderer my mounts yesterday from gmpartsdirect umm. do u have a hard shift into gears like from park to drive ? i know I do but it comes and goes some times it's not as hard as others idk im just going to change them both in see what happens
- JBMark33
- Posts like an L36
If you can remember in what order you removed things to get to the rear mount, maybe we could make a write-up of the replacement process. I still need to get under my car and check to see if mine is damaged.
- JBMark33
- Posts like an L36
My rear mount appears to be in one piece, just looks a little extra squishy.
I guess I am just not used to so much engine movement with the stock mounts..
RookieSSei
- SSE Member
ALL STOCK (FOR noW)
okay well, i just replaced the rear and the driver side mount and i still have lots of engine movement looks like i'm going to replace the front one again ( i replaced it with a nappa one this past summer so I'll go oem this time so I hope this fixes the movement this is driving me crazy and into the poor house lol
