How To - Auxillary Line install (mp3yourcar.com accesory)
Night Crawler
Year and Trim: 2002 Bonneville SE
Post by Night Crawler »
Couple things you need other than tools.
Image 25 feet long
A drill, a 3/8 and 5/16 drill bits
Auxiliary adapter has toggle switches on the one side. All the pins should be up when you get it. Push 1, 3, and 8 down to on. (The website that the instructions send you to has this wrong)
First remove the rear trunk panel, carpeting, front trunk panel (held on by 3 magnets) and take out the cd changer
Remove the insides. (This is where the axillary unit will be put inside of.)
Run the rca's out the back of the empty cd box and push the factory plug from cd box into the box. (This gets a little tricky to plug the harnesses together)
Now run the rca cables under the back seat
Make sure you remove the two finishing trim pieces that run along the edge of the car. Then you'll have to use a some sort of object to fish the cables through the center pillar. (i used a bike lock cable)
Remove the plastic shield under the glove box. (2 screws hold it on)
Remove this part of the dash (you'll have to pop of the gauge trim first. 2 pins hold it on above the gauges and the rest pops off.)
Drill a counter sink hole using the 3/8 bit. (don't go to far) Then drill the rest of the hole with the 5/16 drill bit. Finally use the 3/8 bit, make the counter sink hole a little deeper.
This part comes apart by unscrewing the chrome ring
Insert the aux plug through the back and screw the chrome ring back on and reinstall the part back in the car. Running the wires towards the glove box.
Connect the aux cable and the rca cables together with the female to female adapter shown above.
Then reassemble the car and now you have an axillary line that looks stock.
Last edited by Night Crawler on Fri Feb 13, 2009 8:12 pm, edited 3 times in total.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
Night Crawler
Re: How To - Auxillary Line install (mp3yourcar.com accesory)
no replys, :(
2002 Bonneville SE
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Here's your reply!
Sweet!
Does this hook up through the antenna?
Loss of the cd changer?
I like this way better: viewtopic.php?f=13&t=318
Night Crawler
LeSabre in Buffalo wrote:Here's your reply!
Sweet!
I actually just plugs into the plug that the cd changer uses making the cd changer useless. Hence why I gutted it and used it to put the components into.
I couldn't stand the CD changer, every time I went to play cd's from it they skipped like crazy due to dust build up. Now I have auxillary input so I don't need cd's anymore. Anything with a headphone jack can plug into it. Plus I couldn't do the other method.
2002 Bonneville SE
bonnevillain
Post by bonnevillain »
I never had any problems with my cd changer, but i got usb functionality now, so i just carry an 8 gig usb flash drive with me and use the aftermarket head unit to browse through folders and songs :D
looks like a very easy install though
Night Crawler
yep it was
2002 Bonneville SE
PSH, who needs an AUX in when you have XM and a 12 disc changer?
bonnevillain
a disk changer that only plays audio cds is nothing compared to a 60GB ipod/mp3 player, or a laptop on a trip, or even an 8 gig flash drive with a few thousand songs on it versus maybe 20 songs per cd with the stock changer
True, but I can fit all of the songs I listen to on 12 CD's in my changer, lol.
biohazed
Year and Trim: 2000 Grand PRix GTP
Post by biohazed »
cool mod but not everyone has a factory 12 disc changer so i can't do this mod :(
- 2000 Bonneville SE 3800 Series 2, Aluminum LIM Gasket, Dorman Improved UIM - Sold
Night Crawler
I lucked out with the changer in my se. I don't have satellite radio and don't want it. Because why pay for radio when you can have a whole bunch of songs on mp3 on a lap top including movies. the new 8.9" lap top by acer that are out fit between the seats no problem once the car is in drive.
2002 Bonneville SE
You mean the EEE?
bonnevillain
it's an acer ;)
Night Crawler
2002 Bonneville SE
