DRL disable
DRL disable
Post by gonzo4191 »
i just tried to disable the daytime's, but i can't get it to work....can someone help me...supplied a picture
between the two grey 8567 to the right :)
Re: DLR disable
I edited your post from DLR to DRL ;)
For the 00 guys.... This is the DRL Disable in the fuse block under the hood. Remove the relay and jump these connections.
If you don't jump the connections, the passenger's side head light will be out when you turn on the high beam.
Open the hood, remove the cover on the fuse box, find the location on the fuse block (I rotated the pic as if you were standing in front of the passenger side headlight). Pull out the relay for the DRLs. Take a small piece of wire and two ends and make a jumper. Plug the jumper in to the terminals and try starting the car.
Re: DRL disable
Post by gonzo4191 »
wow im a noob, i tried every connection but that one, and i even had that post bookmarked
robjr69
Year and Trim: 1996 Pontiac Bonneville SE
Re: DRL disable
Post by robjr69 »
At first I took out the DRL relay and bent a few prongs back and then plugged back in. I then seen that there is a DRL fuse by the DRL relay. I pulled the fuse and it disabled the DRL. I bent the prongs back to the normal state and plugged back in. My auto lights still work at night I just dont have the DRL anymore.
bonnevillain
Re: DRL disable
Post by bonnevillain »
do both your high beams work?
robjr69
Re: DRL disable
Post by robjr69 »
Sorry man I didnt realize that your DRL's were your high beams. Mine is a 05 and the DRL's were the low beams. I disconnected them cause I got a H.I.D conversion kit. Try just removing the relay and check the highbeams...Good luck and again im sorry.
2000Silverbullet
Re: DRL disable
Post by 2000Silverbullet »
I tried Haro's trick and nothing happened. :???:
I pulled the fuse and jumpered the two connections. Start the car and the lights are on and the high beams work just like I didn't pull or connect anything! ??
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: DRL disable
Post by 2003 SSEi »
2000Silverbullet wrote:I tried Haro's trick and nothing happened. :???:
you have to pull the RELAY
2000Silverbullet
Re: DRL disable
Ahhh, yes, I meant to say, I pulled the relay........and everything works as it should. :wink: :banana: :banana:
Last edited by 2000Silverbullet on Sat Sep 27, 2008 11:37 pm, edited 1 time in total.
Re: DRL disable
The picture is rotated as if you were standing behind the panel, looking at it from the hood hinge, I just noticed that. Might confuse someone.
Re: DLR disable
Post by gonzo4191 »
harofreak00 wrote:I edited your post from DLR to DRL ;)
Re: DLR disable
Juan, go look at the fuse box in your car and tell me where it is. That picture is the exact opposite of what mine looks like from standing in front of the passenger headlight. I believe the OP of that thread made a mistake.
EWC88
Year and Trim: 01 Se
Re: DRL disable
Post by EWC88 »
What does disablingn DRL's do? Also anyone recommend or can chime in on what they used at the end of there wire that connects into the fuse box?
R.I.P 2001 Se :(
Re: DRL disable
It prevents your headlights from being on during the day as daytime running lights. The still work as they should at night. I used a ground down spade connector.
EWC88
Re: DRL disable
Post by EWC88 »
Oh ok, I am going do this for sur then. Now do they come on own there own when it gets dark or do I have to do it?
Ed did you use these: http://www.radioshack.com/product/index ... Id=3028789
R.I.P 2001 Se :(
Re: DRL disable
This is a stupid mod IMO. Why would you want to disable a factory safety feature? You all know that you can see a car better (even during the day) when its headlights are on. The bulbs are only on at half brightness, so its not going to burn out your bulbs by leaving it enabled.
bonnevillain
Re: DRL disable
yes they still come on when it gets dark.
I just twisted a wire and shoved it in there, it's been fine for close to a year now.
ddalder
Re: DRL disable
Post by ddalder »
EWC88 wrote:What does disablingn DRL's do? Also anyone recommend or can chime in on what they used at the end of there wire that connects into the fuse box?
Well, it makes you less visible. It increases your chances of being in a collision. Other than that, well... It's really personal preference.
robjr69
Re: DRL disable
Post by robjr69 »
I disabled mine because the low beams are on all the time and if they are on day and night the headlight assembly will get hot and then the heat from the sun makes them look real bad. thats why you see alot of the cars incliding bonnevilles with faded and yellow headlight lenses. mine is 4 years old and you can see by my pics that they are not yellow or faded whatsoever. but I agree is personal preference.
lewis26
Year and Trim: 2003 SLE || 51k miles
Re: DRL disable
Post by lewis26 »
The fading has nothing to do with your DRLs. Most heat issues come from plug and play HID kits.
Disabling them helps you and your car in no way whatsoever. It makes you far less visible to oncoming traffic.
Next time you're on the highway, take a look at oncoming traffic. Which cars can you see earlier? The ones with DRL's/headlights on, or the ones without?
-Mike
Locked
