It is currently Thu Apr 19, 2018 1:13 pm
PostPosted: Sat Jul 10, 2010 7:16 pm
I have a 02 Bonneville with 98k. It started shifting hard after being driven around town.
The more times I shifted through the gears, the rougher the shifts became. :???: I asked
my wife to shift the car into drive while holding down the brake pedal to observe the
engine movement - and holy cow - it moves 2-3 inches. :eek: Time for a front motor
mount change! Here's where it is and what it looks like:
Here is what the new one looks like. Initially, the dealer asked $159.99 for it. I asked him
for a better price, and he ended up selling it to me for $129.99.
Here are the tools I used. The socket size was 11/16 for the 3/4 drive, and 15 mm for the 3/8 drive.
Here is how I positioned my jacks to support the motor. I found out the larger jack on wheels
dropped slightly, but the red one held strong. Slight pressure is all that was needed - just
enough to see the car move up about an inch.
Here is a partial disassembly - after disconnecting the hose and electrical to and
removing the cannister from the mount bracket.
Complete removal of bracket and mount - ready for reassembly. Lock tight was used
on the studs, and I double nutted the old mount in place of buying new nuts.
It took just over an hour, including clean up. Test drove the car and - wow - awesome
smooth shifts. :banana: Even took it up to Minneapolis and ran it around there from
stop light to stop light, and no further troubles. It's cured. Easy fix. Costs more than
using hockey pucks, which I gave some serious thought to - I was concerned I would
get some annoying vibes so I caved and bought OE replacement.
PostPosted: Sat Jul 10, 2010 7:29 pm
I'd like to move this to a different forum - is this possible?
PostPosted: Sat Jul 10, 2010 7:35 pm
First off, welcome!! I see you're from MN, we have quite a few MN members.
Good write-up, I'll be doing the hockey pucks myself soon. :wink:
I believe you meant 1/2 in drive? I have a 3/4 inch drive set, and those don't look that big.
PostPosted: Sat Jul 10, 2010 9:55 pm
1994 Bonneville SSEI
2006 Grand Prix GXP
Looks like the ratchet is 1/2 and the extension is 3/8
PostPosted: Sat Jul 10, 2010 9:57 pm
That is what I'm referring to.
PostPosted: Sun Jul 11, 2010 8:25 am
It's 1/2 inch drive. I have a Snap - On brand set that has served me well over the years. The rest of my tools are a potpourri of brands, but always seem to get the work done.
PostPosted: Sun Jul 11, 2010 8:38 am
Just bought the car 3 weeks ago with 98k for $5900.00. It's a one owner trade from New Jersey. I first opened the trunk to make sure Jimmy Hoffa wasn't in there. Very clean. Bought at auction in Shakopee. It was serviced at a Cadillac dealership in a suburb of New York City, close to the Hudson River (Carfax). It was well maintained - no oil leaks. This was the only serious problem to surface. The minor troubles I have are need to replace a few dash lights (no big deal), and solder in some new led's into the radio display, which I'll try and hope for good results. I want the display to work-- If the radio display fix fails, I'll just purchase aftermarket at some future date. Other than that, the car is fantastic and I love driving it.
PostPosted: Tue Dec 06, 2011 9:03 pm
Year and Trim: 2000 Bonneville SE
Hi,
I'm mrwildroot, a newbie to this forum.
Found you because of a defective motor mount on my 2000 Bonnie SE. (57,000 orig miles).
Thanks to this specific post, I'm clear on what to do next.
Needing a 15mm Deep Socket, and I'll have this problem licked.
My questions would be about getting the studs out of the engine block..why and how???
Off to buy a set of deep metric sockets tomorrow morning.
Curious also about Standard 11/16 nuts on Motor Mount, and Metric (15mm) on the Motor Mount Bracket....
There are no new unread posts for this topic. 1993 SSE: 17 years of pictures to replace photobucket loss
John Deere Boy
11
496
Wed Jan 31, 2018 4:16 pm
Namrepus28 View the latest post
There are no new unread posts for this topic. solid mount
1648
Thu Nov 20, 2008 6:38 pm
There are no new unread posts for this topic. hockey puck mount
redeyesbonnie
Mon Mar 16, 2009 10:40 pm
Night Crawler View the latest post
There are no new unread posts for this topic. Tested out my new suction cup mount.
SSEiMan01
21
1212
Mon Feb 27, 2012 11:10 pm
There are no new unread posts for this topic. Epic Mount Failure and the Solution
WhiteArrow3800
39
1870
Thu Mar 12, 2009 10:34 pm
