HP Tuner
deano55
HP Tuner
Post by deano55 »
I'm still wanting to go in with 3 others on the Hp tuner set up if interested. If you are in the southern suburbs of chicago and would like to learn how to use these tuners I'm in.
Re: HP Tuner
I will definitely chip in for this.
deano55
Re: HP Tuner
Post by deano55 »
If we get 3 more people thats roughly 100.00 apiece with 8 credits. Learning to operate it will be a challenge but with 4-5 people working together will help.
Re: HP Tuner
Do you know if one credit will cover both your car and mine? Or are they trim specific? Also, Will might want in on this.
deano55
Re: HP Tuner
Post by deano55 »
I'm not sure if multiple cars can use the exact same tune or are they vin number tagged?
deano55
Re: HP Tuner
Post by deano55 »
http://www.hptuners.com/products/vcmsui ... faq.php#a8 maybe if you read this you will understand better, looks to me it takes more than one credit to do one car?
Re: HP Tuner
You can either buy a model year of a car, or you can buy the credits per VIN. Our cars take 2 credits for one individual car.
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Re: HP Tuner
Post by bobtaz13 »
I might consider loaning mine out. But until I get my P0171 issue fixed it is tied up.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
deano55
Re: HP Tuner
Post by deano55 »
bobtaz13 wrote:I might consider loaning mine out. But until I get my P0171 issue fixed it is tied up.
thats really generous of you, but it would be nice if it were local
sethjamesrimrodt
Year and Trim: 2004 GXP
Re: HP Tuner
Post by sethjamesrimrodt »
3 credits will do all 2000 bonnevilles for example. It's pretty easy to use once you have the software installed on your computer. I like mine.
Edit: it may not be 3 credits but that's what I recall.
Last edited by sethjamesrimrodt on Sat May 05, 2012 12:01 pm, edited 1 time in total.
Seth
deano55
Re: HP Tuner
Post by deano55 »
There has to be plenty people around me that can ise this?
SSEiMan01
Re: HP Tuner
Post by SSEiMan01 »
I'm in.
James May wrote:Hello.
SSEiMan01
Re: HP Tuner
Post by SSEiMan01 »
Shot in the dark, can the software be installed on more than one pc? Im in either way but figured I would ask for the sake of convenience.
Re: HP Tuner
Yes, it's just a CD you install the software off of, you just have to use a code or something to be able to tune.
SSEiMan01
Re: HP Tuner
Post by SSEiMan01 »
I'm in fasho then!
deano55
Re: HP Tuner
Post by deano55 »
2 more people?
deano55
Re: HP Tuner
Post by deano55 »
or 1?
sandrock
Re: HP Tuner
Post by sandrock »
A new HPT will ship with 4 credits. It takes two credits to unlock ONE vehicle. It takes 4 credits to unlock ONE model, ONE year. In other words, 4 credits will allow the full 2001 Bonneville spread, be it supercharged or not. Extra credits are 50 bucks each, most vehicles will take two.
deano55
Re: HP Tuner
Post by deano55 »
VCM Suite
VCM Suite is designed for both the home enthusiast and the professional tunershop. Includes VCM Editor and VCM Scanner! 8 credits are included which is enough to tune at least two vehicles and in some cases, four or more vehicles! Now that I'm totally confused as to haow many cars we can actually tune for the 500.00, I would like to make sure before I drag you guys into this thinking we are going to get all 4 or 5 people tuned for the initial money. This is saying some cars take 4 credits, so that would at the worst case be 2 cars for the 8 credits or we all might get tuned. If it's the worst case that would be buying more credits and therefore would cost more than I originally thought :dontknow: . How can I find out for sure? Call them?
sandrock
Re: HP Tuner
Post by sandrock »
Thats right. I bought mine used and it had 4 credits left :???:
