It is currently Tue Jun 19, 2018 8:13 am
PostPosted: Fri May 14, 2010 10:00 pm
Year and Trim: 1996 pontiac bonneville se
What is the normal engine temperature on 92-99 bonnevilles?? at times when i have on my ac my engine gets up to 210. and why all none of the bonneville coolant fan dont work when the ac is off?
PostPosted: Fri May 14, 2010 10:57 pm
The temps sound about normal. If the low speed fan relay is dead, your fans won't work until the high speed is commanded (when temps are hot enough and/or the AC is on).
PostPosted: Sat May 15, 2010 12:46 am
1993 Bonneville SSE
The stock thermostat is a 195*. So around there would be normal. IIRC, The highspeed fans should come on around 210-215* or when the AC is on.
'93 SSE "Guinevere" Mods: Intense FWI | 180ยบ T-Stat | Flowmaster 80 | Magnaflow Cat | Projector Fogs | Clear Corners | ES Poly End Links
Achievements: Guinevere - 264k mi | 16.27 @ 84.10mph | March '11 COTM :: Chloe - 223k mi | 13.85 @ 102mph | January '09 COTM
There are no new unread posts for this topic. 2000 pontiac bonneville engine codes
emaddox
Fri May 01, 2015 11:17 pm
There are no new unread posts for this topic. Welcome to the Pontiac Bonneville Club!!
SSEi95
Tue Aug 04, 2009 12:23 pm
SSEi95 View the latest post
There are no new unread posts for this topic. my 1990 pontiac bonneville sse
Jack39
Tue Sep 01, 2015 7:10 am
RJolly87 View the latest post
There are no new unread posts for this topic. pontiac bonneville cloth top?
samanthakaitlyn
Tue Apr 12, 2011 3:18 pm
Gumball View the latest post
There are no new unread posts for this topic. Value of This 1979 Pontiac Bonneville???
tvanslooten
Tue May 17, 2011 8:44 pm
wake View the latest post
